1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2
To: "Madden, Timothy J." <[email protected]>
Date: Fri, 2 Oct 2015 22:20:32 +0000
It looks like you are using Cgywin make. That is not allowed. See. The page on building with Windows on EPICS base page. Use make 4.1 linked to there.
Sent from my iPhone
> On Oct 2, 2015, at 5:15 PM, Madden, Timothy J. <[email protected]> wrote:
> Mark
> Thanks for the reply.
> Here is the error message. I saw someone else had gotten a similar message. With other epics base it goes away, but the 2015 compiler does not work with older EPICS.
> Tim
> See below-----------------------------------------------
> D:\EPICS\ADEpics\synApps_5_5\support\seq-2.2.3>make
> cygwin warning:
>  MS-DOS style path detected: D:/EPICS/ADEpics/base-3.15.2/configure/CONFIG
>  Preferred POSIX equivalent is: /cygdrive/d/EPICS/ADEpics/base-3.15.2/configure
> /CONFIG
>  CYGWIN environment variable option "nodosfilewarning" turns off this warning.
>  Consult the user's guide for more details about POSIX paths:
>    http://cygwin.com/cygwin-ug-net/using.html#using-pathnames
> make -C ./configure install
> make[1]: Entering directory `/cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2
> .2.3/configure'
> perl -CSD /cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2.2.3/configure/D:/E
> PICS/ADEpics/base-3.15.2/bin/windows-x64-debug/makeMakefile.pl O.windows-x64-deb
> ug ../..
> Can't open perl script "/cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2.2.3/
> configure/D:/EPICS/ADEpics/base-3.15.2/bin/windows-x64-debug/makeMakefile.pl": N
> o such file or directory
> make[1]: *** [O.windows-x64-debug] Error 2
> make[1]: Leaving directory `/cygdrive/d/EPICS/ADEpics/synApps_5_5/support/seq-2.
> 2.3/configure'
> make: *** [configure.install] Error 2
> -----------------------------------------------END------------------------------------------------
> From: Mark Rivers [[email protected]]
> Sent: Friday, October 02, 2015 4:50 PM
> To: Madden, Timothy J.
> Cc: [email protected]
> 2.2.3 does work for me with VS 2010 and 3.14.12.5. It was 2.2.2 that did not work. I have not tested your combination of compiler and base, but please send the error message.
> Mark
> Sent from my iPhone
> On Oct 2, 2015, at 4:20 PM, Madden, Timothy J. <[email protected]<mailto:[email protected]>> wrote:
> Dear EPICS:
> Trying to build seq 2.2.3 with epics base 3.15.2. I am using the windows 2015 compiler on a 64 bit machine.
> I am building in 64 bit mode.
> I saw some tech talk notes that this does not work?
> Mark R. says one can make this work with 2.2.x snapshot etc. etc. I don't know where to get this. it is not on the seq web site.
> Thanks
> Tim Madden
> APS
RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Mark Rivers
Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Madden, Timothy J.
Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Mark Rivers
RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Madden, Timothy J.
Prev: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Ben Franksen
Next: RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Madden, Timothy J.
