1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS S7plc driver & TIA Portal
To: [email protected]
Date: Fri, 16 Oct 2015 15:01:13 +0200
Hello,
I have to send datas from siemens S7-300 PLC to EPICS S7plc driver via a TCP connection. The Siemens software used to configure the plc is TIA portal V13 SP1. The documentation "EPICS using SLS s7plc driver" is written with the previous version, Simatic manager example and my tries show me that the procedure is a bit different.
Does anyone have experience in programming S7-300 plc's with TIA PORTAL in the same goal? Ideally an example program?
Is it possible that TIA Portal configuration could be an issue for the EPICS S7plc driver?
I would also like to know if the documentation "EPICS using SLS s7plc driver" will be upgraded to explain the procedure with the new siemens TIA Portal Software?
Thank you in advance
yours sincerely
Remi FAURE
Engineer Assistant at LPSC Grenoble-CNRS
Prev: Program for the EPICS user collaboration meeting in Melbourne is now available Juan.Guzman
Next: Reuqest for CSS PV Table new feature Patard Charles-Henri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS S7plc driver & TIA Portal Nick Levchenko
