1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS S7plc driver & TIA Portal
Date: Fri, 23 Oct 2015 14:28:35 +0000
Hi Remi,
I have just recently gone through setting up EPICS comms to S7-1500 PLC using TIA Portal.
I have used the document from PSI that you have referred to as a basis.
The fact that you are using TIA portal instead of SIMATIC Manager doesn’t actually change anything on EPICS side.
It only changes the way you set up the comms block in the PLC. But it is actually very similar, just the user interface is different and you might have to use different SND and RCV blocks. You might even have to use slightly different SND and RCV blocks from my example since you’re using S7-300 and I’m using S7-1500, but this is easily obvious once you get to this stage.
I have created a simple step-by-step guide similar to the one PSI created but for TIA Portal. Unfortunately I have not had time to make it pretty yet, so for now it’s just a collection of steps with relevant screenshots. Let me know if you’re interested and I can e-mail it to you.
______________________
Nick Levchenko
Control Systems Engineer
Integrated Control System Division
European Spallation Source ERIC
Prev: RE: Modbus TCP communication with PLC IDEC FC5A-D12S1E unable to read Internal Relays Mazanec Tomáš
Next: EDM display update rate jon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS S7plc driver & TIA Portal Remi Faure
Next: Reuqest for CSS PV Table new feature Patard Charles-Henri
