1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn timeout
Date: Mon, 19 Oct 2015 18:24:12 -0300
Hola Mark,
I'd be happy to test the keepalive option when it's ready. It may not happen immediately since the instrument is a shared resource and the time to use it is allocated in blocks.
Thank you,
Pedro.
On 19 October 2015 at 16:10, Mark Rivers <[email protected]> wrote:
Hi Pedro,
It seems like it might be a good idea to add optional keepalive support to the asyn socket driver.  If I were to create a branch on github that implemented this would you be able to test it?
From: [email protected] [mailto:[email protected]] On Behalf Of Pedro Gigoux
Sent: Monday, October 19, 2015 1:46 PM
To: Torsten bögershaus
Cc: [email protected]
Hi Torsten,
The instrument is located in a remote institution so I don't have much details about their network setup. On our side, the machine where the software runs goes through a couple of switches and the firewall before connecting to the remote host. Our IP is registered on their firewall to accept connections to the instrument. According to our IT department we don't have timeouts for outgoing traffic so we suspect the remote network equipment is the one dropping the connection (I don't have hard evidence to support this yet, though). A workaround that has been proposed is to modify the software to send a ping-like packet every minute to prevent the link from going down.
Thank you,
Pedro.
On 19 October 2015 at 12:27, Torsten bögershaus <[email protected]> wrote:
Not with asyn in special, but with all kind of TCP/IP related devices.
TCP/IP has a „Keepalive“, but this is typically 2 hours.
Could you share more information about that "component in the communication chain“ ?
And what happens if the communication is broken ?
Is there a clean FIN on the TCP-layer ?
Is it just dropped ?
Can you run Wireshark on the IOC ?
On the instrument ?
More info is appreciated
Am 19.10.2015 um 16:38 schrieb Pedro Gigoux <[email protected]>:
> Hi,
> We are using asynDriver to talk to an instrument connected to a socket port on a remote site using an ASCII based protocol. The communication works well except that the connection consistently drops when the exposure time is longer than 30 minutes. While the instrument is exposing there's no traffic in the socket; this points to a component in the communication chain that times out if it doesn't see any traffic for more than a certain time. I did not find timeouts in the asynDriver code so I suspect that the problem is in a network switch/firewall. Has anyone seen a similar problem with asyn before?
> Thank you,
> Pedro Gigoux
> Gemini Observatory
asyn timeout Pedro Gigoux
Re: asyn timeout Torsten bögershaus
Re: asyn timeout Pedro Gigoux
RE: asyn timeout Mark Rivers
Prev: RE: asyn timeout Mark Rivers
Next: EPICS alive module moves to GitHub Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
