1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unable to build support modules on Windows, with base 3.15.2
To: "Heesterman, Peter J" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 30 Oct 2015 13:15:42 -0500
Hi Peter,
On 10/30/2015 12:06 PM, Heesterman, Peter J wrote:
> I did just reproduce the textual anomaly, while using make –j4, see
> attached screen shot.
GNU Make from version 4 onwards has a way to control how the output
streams from parallel jobs get displayed. I think all you're seeing is
that several jobs are printing to stdout at the same time and their
output streams are getting mixed up (which is the default behaviour),
but you can control exactly when they get printed with the option -O (or
--output-sync) as described here:
https://www.gnu.org/software/make/manual/html_node/Parallel-Output.html#Parallel-Output
Using 'make -j4 -O' is probably the simplest solution.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
Re: Unable to build support modules on Windows, with base 3.15.2 Bob Soliday
Prev: RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
Next: RE: asynPortDriver callbacks to I/O Intr, how to propagate an error? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
