I am not sure what it wrong, perhaps Andrew or someone else has an idea.
I have not tried Visual Studio 2015, I am using 2010.
-----Original Message-----
From: Klyachko, Alexander Vitalievich [mailto:[email protected]]
Sent: Thursday, November 05, 2015 4:39 PM
To: Mark Rivers
Subject: Re: Building Epics base 3.15.2 in Windows 7
I believe VS2015 Professional was downloaded, unfortunately I have no record of that. I'm pretty sure it is not Express. The output is below.
Thanks much, Alex.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\aklyachk>cd c:\base-3.15.2
c:\base-3.15.2>make --version
GNU Make 4.1
Built for x86_64-w64-mingw32
Copyright (C) 1988-2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
c:\base-3.15.2>make clean uninstall
make -C ./configure clean
make[1]: Entering directory 'c:/base-3.15.2/configure'
perl -CSD -MExtUtils::Command -e rm_rf O.win32-x86 O.Common
make[1]: Leaving directory 'c:/base-3.15.2/configure'
make -C ./src clean
make[1]: Entering directory 'c:/base-3.15.2/src'
make -C ./tools clean
make[2]: Entering directory 'c:/base-3.15.2/src/tools'
make[2]: Leaving directory 'c:/base-3.15.2/src/tools'
make -C tools/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/tools/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/tools/test'
make -C template/base clean
make[2]: Entering directory 'c:/base-3.15.2/src/template/base'
make[2]: Leaving directory 'c:/base-3.15.2/src/template/base'
make -C template/ext clean
make[2]: Entering directory 'c:/base-3.15.2/src/template/ext'
make[2]: Leaving directory 'c:/base-3.15.2/src/template/ext'
make -C ./libCom clean
make[2]: Entering directory 'c:/base-3.15.2/src/libCom'
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom'
make -C libCom/RTEMS clean
make[2]: Entering directory 'c:/base-3.15.2/src/libCom/RTEMS'
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom/RTEMS'
make -C libCom/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/libCom/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom/test'
make -C ca/client clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/client'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/client'
make -C ca/client/tools clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/client/tools'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/client/tools'
make -C ca/legacy/gdd clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/legacy/gdd'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/gdd'
make -C ca/legacy/pcas clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas'
make -C ./build clean
make[3]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas/build'
make[3]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas/build'
make -C ./example clean
make[3]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas/example'
make -C ./directoryService clean
make[4]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas/example/directoryService'
make[4]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas/example/directoryService'
make[3]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas/example'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas'
make -C ./ioc clean
make[2]: Entering directory 'c:/base-3.15.2/src/ioc'
make[2]: Leaving directory 'c:/base-3.15.2/src/ioc'
make -C ca/legacy/pcas/ex clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas/ex'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas/ex'
make -C ca/client/perl clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/client/perl'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/client/perl'
make -C ioc/db/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/ioc/db/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/ioc/db/test'
make -C ioc/dbtemplate/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/ioc/dbtemplate/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/ioc/dbtemplate/test'
make -C ./std clean
make[2]: Entering directory 'c:/base-3.15.2/src/std'
make[2]: Leaving directory 'c:/base-3.15.2/src/std'
make -C std/filters/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/std/filters/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/std/filters/test'
make -C std/rec/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/std/rec/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/std/rec/test'
make[1]: Leaving directory 'c:/base-3.15.2/src'
perl -CSD -MExtUtils::Command -e rm_rf ./bin/win32-x86
perl -CSD -MExtUtils::Command -e rm_rf ./lib/win32-x86
perl -CSD -MExtUtils::Command -e rm_rf ./dbd ./include ./doc ./html ./templates ./db ./adl ./alh ./cfg ./edl ./lib/perl ./lib/pkgconfig
c:\base-3.15.2>make
make -C ./configure install
perl -CSD ../src/tools/makeMakefile.pl O.win32-x86 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../.. \
T_A=win32-x86 install
make[2]: Entering directory 'c:/base-3.15.2/configure/O.win32-x86'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'c:/base-3.15.2/configure/O.win32-x86'
make -C ./src install
make -C ./tools install
perl -CSD ../../src/tools/makeMakefile.pl O.win32-x86 ../../..
make -C O.win32-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'c:/base-3.15.2/src/tools/O.win32-x86'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/macLib.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Base.pm"
mkdir ../../../lib/perl/DBD
"Installing PERL_MODULES file ../../../lib/perl/DBD/Breaktable.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Device.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Driver.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Function.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Menu.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Output.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Parser.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recfield.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recordtype.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Registrar.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Variable.pm"
"Expanding epics-base-win32-x86.pc@ to epics-base-win32-x86.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-win32-x86.pc"
mkdir ../../../lib/pkgconfig
"Expanding ../epics-base.pc@ to epics-base.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base.pc"
"Installing created executable ../../../bin/win32-x86/convertRelease.pl"
mkdir ../../../bin/win32-x86
"Installing created executable ../../../bin/win32-x86/cvsclean.pl"
"Installing created executable ../../../bin/win32-x86/dos2unix.pl"
"Installing created executable ../../../bin/win32-x86/expandVars.pl"
"Installing created executable ../../../bin/win32-x86/fullPathName.pl"
"Installing created executable ../../../bin/win32-x86/installEpics.pl"
"Installing created executable ../../../bin/win32-x86/makeIncludeDbd.pl"
"Installing created executable ../../../bin/win32-x86/makeMakefile.pl"
"Installing created executable ../../../bin/win32-x86/makeTestfile.pl"
"Installing created executable ../../../bin/win32-x86/mkmf.pl"
"Installing created executable ../../../bin/win32-x86/munch.pl"
"Installing created executable ../../../bin/win32-x86/replaceVAR.pl"
"Installing created executable ../../../bin/win32-x86/useManifestTool.pl"
"Installing created executable ../../../bin/win32-x86/dbdToMenuH.pl"
"Installing created executable ../../../bin/win32-x86/dbdToRecordtypeH.pl"
"Installing created executable ../../../bin/win32-x86/dbdExpand.pl"
"Installing created executable ../../../bin/win32-x86/dbdToHtml.pl"
"Installing created executable ../../../bin/win32-x86/podToHtml.pl"
"Installing created executable ../../../bin/win32-x86/podRemove.pl"
"Installing created executable ../../../bin/win32-x86/registerRecordDeviceDriver.pl"
"Installing html ../../../html/./style.css"
mkdir ../../../html
mkdir ../../../html/.
make[3]: Leaving directory 'c:/base-3.15.2/src/tools/O.win32-x86'
make -C tools/test install
perl -CSD c:/base-3.15.2/bin/win32-x86/makeMakefile.pl O.win32-x86 ../../../..
make -C O.win32-x86 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory 'c:/base-3.15.2/src/tools/test/O.win32-x86'
perl -CSD -MExtUtils::Command -e cp ../Breaktable.plt Breaktable.t
perl -CSD -MExtUtils::Command -e cp ../DBD.plt DBD.t
perl -CSD -MExtUtils::Command -e cp ../Device.plt Device.t
perl -CSD -MExtUtils::Command -e cp ../Driver.plt Driver.t
perl -CSD -MExtUtils::Command -e cp ../Function.plt Function.t
perl -CSD -MExtUtils::Command -e cp ../macLib.plt macLib.t
perl -CSD -MExtUtils::Command -e cp ../Menu.plt Menu.t
perl -CSD -MExtUtils::Command -e cp ../Recfield.plt Recfield.t
perl -CSD -MExtUtils::Command -e cp ../Recordtype.plt Recordtype.t
perl -CSD -MExtUtils::Command -e cp ../Registrar.plt Registrar.t
perl -CSD -MExtUtils::Command -e cp ../Variable.plt Variable.t
make[3]: Leaving directory 'c:/base-3.15.2/src/tools/test/O.win32-x86'
make -C template/base install
make[3]: Entering directory 'c:/base-3.15.2/src/template/base/O.win32-x86'
"Installing created executable ../../../../bin/win32-x86/makeBaseApp.pl"
"Installing ../../../../templates/makeBaseApp/top/Makefile"
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseApp/top/configure
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseApp/top/configure/Makefile"
"Installing ../../../../templates/makeBaseApp/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseApp/top/supportApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp
"Installing ../../../../templates/makeBaseApp/top/supportApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp/Db
"Installing ../../../../templates/makeBaseApp/top/supportApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp/src
"Installing ../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd"
"Installing ../../../../templates/makeBaseApp/top/iocApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp
"Installing ../../../../templates/makeBaseApp/top/iocApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp/Db
"Installing ../../../../templates/makeBaseApp/top/iocApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp/src
"Installing ../../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp/Db
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp/src
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleBoot
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common"
mkdir ../../../../templates/makeBaseApp/top/exampleBoot/ioc
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@windows"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@cygwin"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/caClientApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/caClientApp
"Installing ../../../../templates/makeBaseApp/top/caClientApp/caExample.c"
"Installing ../../../../templates/makeBaseApp/top/caClientApp/caMonitor.c"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/caServerApp
"Installing ../../../../templates/makeBaseApp/top/caServerApp/README"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exChannel.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exServer.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exServer.h"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/main.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/test.adl"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocBoot
"Installing ../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common"
mkdir ../../../../templates/makeBaseApp/top/iocBoot/ioc
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@windows"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@cygwin"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS"
make[3]: Leaving directory 'c:/base-3.15.2/src/template/base/O.win32-x86'
make -C template/ext install
make[3]: Entering directory 'c:/base-3.15.2/src/template/ext/O.win32-x86'
"Installing created executable ../../../../bin/win32-x86/makeBaseExt.pl"
"Installing ../../../../templates/makeBaseExt/top/Makefile"
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
"Installing ../../../../templates/makeBaseExt/top/README"
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseExt/top/configure
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseExt/top/configure/Makefile"
"Installing ../../../../templates/makeBaseExt/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc"
mkdir ../../../../templates/makeBaseExt/top/configure/os
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc"
"Installing ../../../../templates/makeBaseExt/top/src/Makefile"
mkdir ../../../../templates/makeBaseExt/top/src
"Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/exampleExt
"Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c"
"Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM"
"Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory 'c:/base-3.15.2/src/template/ext/O.win32-x86'
make -C ./libCom install
make[3]: Entering directory 'c:/base-3.15.2/src/libCom/O.win32-x86'
perl -CSD ../../../src/libCom/misc/makeEpicsVersion.pl -o epicsVersion.h ../../../configure/CONFIG_BASE_VERSION
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 3.15.2
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m forceBadAllocException.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../
../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I..
/../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCo
m/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../s
rc/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../
src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include forceBadAllocException.d ../../../src/libCom/osi/os/WIN32/f
orceBadAllocException.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m setThreadName.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src
/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../sr
c/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -
I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom
/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCo
m/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include setThreadName.d ../../../src/libCom/osi/os/WIN32/setThreadName.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsGetopt.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
ibCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/
libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I.
./../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/m
isc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsGetopt.d ../../../src/libCom/osi/os/WIN32/epicsGetopt.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_parser.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include yajl_parser.d ../../../src/libCom/yajl/yajl_parser.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_lex.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
om/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/lib
Com/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../.
./../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc
-I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yac
c -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include yajl_lex.d ../../../src/libCom/yajl/yajl_lex.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_gen.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
c -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include yajl_gen.d ../../../src/libCom/yajl/yajl_gen.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_encode.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include yajl_encode.d ../../../src/libCom/yajl/yajl_encode.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_buf.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
c -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include yajl_buf.d ../../../src/libCom/yajl/yajl_buf.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl_alloc.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/li
bCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/l
ibCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I..
/../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/mi
sc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/y
acc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include yajl_alloc.d ../../../src/libCom/yajl/yajl_alloc.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m yajl.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/o
si/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/
cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../..
/src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I.
./../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I
../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include yajl.d ../../../src/libCom/yajl/yajl.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m timerQueuePassive.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../..
/src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../.
./src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdm
gr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/li
bCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/l
ibCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include timerQueuePassive.d ../../../src/libCom/timer/timerQueuePassive.
cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m timerQueueActiveMgr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../
../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../..
/../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/f
dmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/
libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src
/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include timerQueueActiveMgr.d ../../../src/libCom/timer/timerQueueActi
veMgr.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m timerQueueActive.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../
src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../..
/src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmg
r -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/lib
Com/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/li
bCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include timerQueueActive.d ../../../src/libCom/timer/timerQueueActive.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m timerQueue.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/li
acc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include timerQueue.d ../../../src/libCom/timer/timerQueue.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m timer.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/
osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom
/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../.
./src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I
../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -
I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include timer.d ../../../src/libCom/timer/timer.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsTimer.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/li
acc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsTimer.d ../../../src/libCom/timer/epicsTimer.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m taskwd.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom
/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCo
m/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../
../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -
I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include taskwd.d ../../../src/libCom/taskwd/taskwd.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsRingBytes.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../sr
c/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../s
rc/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr
-I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCo
m/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libC
om/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsRingBytes.d ../../../src/libCom/ring/epicsRingBytes.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsRingPointer.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../
bCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsRingPointer.d ../../../src/libCom/ring/epicsRingPointer.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m threadPool.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/li
acc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include threadPool.d ../../../src/libCom/pool/threadPool.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m poolJob.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
m/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libC
om/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../..
-I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include poolJob.d ../../../src/libCom/pool/poolJob.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdFindAddr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdFindAddr.d ../../../src/libCom/osi/os/default/osdFindAddr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdBackTrace.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/
libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src
/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I
../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/
misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom
/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdBackTrace.d ../../../src/libCom/osi/os/WIN32/osdBackTrace.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsStackTrace.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../s
rc/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../
src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr
om/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/lib
Com/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsStackTrace.d ../../../src/libCom/osi/epicsStackTrace.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m devLibVMEOSD.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/
/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include devLibVMEOSD.d ../../../src/libCom/osi/os/default/devLibVMEOSD.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m devLibVME.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
Com/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/li
bCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../
../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/mis
c -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/ya
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include devLibVME.d ../../../src/libCom/osi/devLibVME.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdMessageQueue.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../s
Com/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdMessageQueue.d ../../../src/libCom/osi/os/default/osdMessageQue
ue.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdNetIntf.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/li
acc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdNetIntf.d ../../../src/libCom/osi/os/WIN32/osdNetIntf.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdProcess.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/li
acc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdProcess.d ../../../src/libCom/osi/os/WIN32/osdProcess.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdTime.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdTime.d ../../../src/libCom/osi/os/WIN32/osdTime.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdEvent.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
c -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdEvent.d ../../../src/libCom/osi/os/WIN32/osdEvent.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdSpin.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdSpin.d ../../../src/libCom/osi/os/default/osdSpin.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdMutex.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
c -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdMutex.d ../../../src/libCom/osi/os/WIN32/osdMutex.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdThreadHooks.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../sr
om/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdThreadHooks.d ../../../src/libCom/osi/os/default/osdThreadHooks.
c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdThreadExtra.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../sr
om/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdThreadExtra.d ../../../src/libCom/osi/os/WIN32/osdThreadExtra.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdThread.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdThread.d ../../../src/libCom/osi/os/WIN32/osdThread.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdStdio.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
c -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdStdio.d ../../../src/libCom/osi/os/WIN32/osdStdio.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsStdio.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/li
acc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsStdio.d ../../../src/libCom/osi/epicsStdio.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsTempFile.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src
m/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsTempFile.d ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsReadline.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src
m/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsReadline.d ../../../src/libCom/osi/os/default/epicsReadline.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdEnv.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdEnv.d ../../../src/libCom/osi/os/default/osdEnv.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdSignal.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdSignal.d ../../../src/libCom/osi/os/WIN32/osdSignal.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdPoolStatus.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src
m/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdPoolStatus.d ../../../src/libCom/osi/os/WIN32/osdPoolStatus.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdInterrupt.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/
/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdInterrupt.d ../../../src/libCom/osi/os/default/osdInterrupt.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdFindSymbol.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src
m/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdFindSymbol.d ../../../src/libCom/osi/os/WIN32/osdFindSymbol.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdAssert.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdAssert.d ../../../src/libCom/osi/os/default/osdAssert.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsSocketConvertErrnoToString.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default
-I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvt
Fast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../
src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I.
./../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I
../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsSocketConvertErrnoToString.d ../../../src/lib
Com/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m systemCallIntMech.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../..
ibCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include systemCallIntMech.d ../../../src/libCom/osi/os/WIN32/systemCallI
ntMech.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osiSock.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osiSock.d ../../../src/libCom/osi/osiSock.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdSockAddrReuse.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../
bCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdSockAddrReuse.d ../../../src/libCom/osi/os/WIN32/osdSockAddrRe
use.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osdSock.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osdSock.d ../../../src/libCom/osi/os/WIN32/osdSock.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m osiClockTime.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/
/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include osiClockTime.d ../../../src/libCom/osi/osiClockTime.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsGeneralTime.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../
bCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsGeneralTime.d ../../../src/libCom/osi/epicsGeneralTime.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsAtomicOSD.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../sr
om/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsAtomicOSD.d ../../../src/libCom/osi/os/default/epicsAtomicOSD.
cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsMath.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsMath.d ../../../src/libCom/osi/epicsMath.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsMessageQueue.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../..
ibCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsMessageQueue.d ../../../src/libCom/osi/epicsMessageQueue.cp
p
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsTime.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsTime.d ../../../src/libCom/osi/epicsTime.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsEvent.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/li
acc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsEvent.d ../../../src/libCom/osi/epicsEvent.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsMutex.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/li
acc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsMutex.d ../../../src/libCom/osi/epicsMutex.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsThread.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsThread.d ../../../src/libCom/osi/epicsThread.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsUnitTest.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src
m/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsUnitTest.d ../../../src/libCom/misc/epicsUnitTest.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m ipAddrToAsciiAsynchronous.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I
../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -
I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/li
bCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../.
./src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../
../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include ipAddrToAsciiAsynchronous.d ../../../src/libCom/misc/ipA
ddrToAsciiAsynchronous.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m truncateFile.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/
/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include truncateFile.d ../../../src/libCom/misc/truncateFile.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsString.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsString.d ../../../src/libCom/misc/epicsString.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsStdlib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsStdlib.d ../../../src/libCom/misc/epicsStdlib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsExit.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsExit.d ../../../src/libCom/misc/epicsExit.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsConvert.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/
/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsConvert.d ../../../src/libCom/misc/epicsConvert.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m cantProceed.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include cantProceed.d ../../../src/libCom/misc/cantProceed.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m adjustment.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/li
acc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include adjustment.d ../../../src/libCom/misc/adjustment.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m aToIPAddr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include aToIPAddr.d ../../../src/libCom/misc/aToIPAddr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m alarmString.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include alarmString.d ../../../src/libCom/misc/alarmString.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m macUtil.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include macUtil.d ../../../src/libCom/macLib/macUtil.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m macEnv.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include macEnv.d ../../../src/libCom/macLib/macEnv.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m macCore.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include macCore.d ../../../src/libCom/macLib/macCore.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m logClient.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include logClient.d ../../../src/libCom/log/logClient.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m iocLog.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include iocLog.d ../../../src/libCom/log/iocLog.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m libComRegister.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../sr
om/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include libComRegister.d ../../../src/libCom/iocsh/libComRegister.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m registry.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
c -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include registry.d ../../../src/libCom/iocsh/registry.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m iocsh.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/
I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include iocsh.d ../../../src/libCom/iocsh/iocsh.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m gpHashLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include gpHashLib.d ../../../src/libCom/gpHash/gpHashLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m freeListLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include freeListLib.d ../../../src/libCom/freeList/freeListLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m fdManager.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include fdManager.d ../../../src/libCom/fdmgr/fdManager.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m fdmgr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/
I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include fdmgr.d ../../../src/libCom/fdmgr/fdmgr.cpp
perl -CSD ../../../src/libCom/error/makeStatTbl.pl ../../../src/libCom/osi/devLib.h ../../../src/libCom/as/asLib.h ../../../src/libCom/misc/epicsStdlib.h ../../../src/libCom/pool/epicsThrea
dPool.h ../../../src/ioc/db/dbAccessDefs.h ../../../src/ioc/dbStatic/devSup.h ../../../src/ioc/dbStatic/drvSup.h ../../../src/ioc/dbStatic/recSup.h ../../../src/ioc/dbStatic/dbStaticLib.h ..
/../../src/libCom/error/errMdef.h ../../../src/ca/legacy/pcas/generic/casdef.h ../../../src/ca/legacy/gdd/gddAppFuncTable.h
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m errSymTbl.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include errSymTbl.d errSymTbl.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m errSymLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include errSymLib.d ../../../src/libCom/error/errSymLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m errlog.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include errlog.d ../../../src/libCom/error/errlog.c
perl -CSD ../../../src/libCom/env/bldEnvData.pl ../../../configure
Generating envData.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m envData.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include envData.d envData.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m envSubr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include envSubr.d ../../../src/libCom/env/envSubr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m ellLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include ellLib.d ../../../src/libCom/ellLib/ellLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m dbmf.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/o
../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include dbmf.d ../../../src/libCom/dbmf/dbmf.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsSingletonMutex.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../
/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsSingletonMutex.d ../../../src/libCom/cxxTemplates/epicsSi
ngletonMutex.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m epicsOnce.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include epicsOnce.d ../../../src/libCom/cxxTemplates/epicsOnce.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m resourceLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include resourceLib.d ../../../src/libCom/cxxTemplates/resourceLib.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m cvtFast.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include cvtFast.d ../../../src/libCom/cvtFast/cvtFast.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m calcPerform.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include calcPerform.d ../../../src/libCom/calc/calcPerform.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m postfix.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include postfix.d ../../../src/libCom/calc/postfix.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m bucketLib.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/lib
cc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include bucketLib.d ../../../src/libCom/bucketLib/bucketLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m asTrapWrite.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include asTrapWrite.d ../../../src/libCom/as/asTrapWrite.c
"Installing generic include file ../../../include/asLib.h"
mkdir ../../../include
"Installing generic include file ../../../include/asTrapWrite.h"
"Installing generic include file ../../../include/bucketLib.h"
"Installing generic include file ../../../include/postfix.h"
"Installing generic include file ../../../include/cvtFast.h"
"Installing generic include file ../../../include/epicsAlgorithm.h"
"Installing generic include file ../../../include/epicsExcept.h"
"Installing generic include file ../../../include/epicsMemory.h"
"Installing generic include file ../../../include/resourceLib.h"
"Installing generic include file ../../../include/tsDLList.h"
"Installing generic include file ../../../include/tsSLList.h"
"Installing generic include file ../../../include/tsMinMax.h"
"Installing generic include file ../../../include/tsBTree.h"
"Installing generic include file ../../../include/tsFreeList.h"
"Installing generic include file ../../../include/epicsSingleton.h"
"Installing generic include file ../../../include/epicsGuard.h"
"Installing generic include file ../../../include/epicsOnce.h"
"Installing generic include file ../../../include/dbmf.h"
"Installing generic include file ../../../include/ellLib.h"
"Installing generic include file ../../../include/envDefs.h"
"Installing generic include file ../../../include/epicsPrint.h"
"Installing generic include file ../../../include/errMdef.h"
"Installing generic include file ../../../include/errSymTbl.h"
"Installing generic include file ../../../include/errlog.h"
"Installing generic include file ../../../include/error.h"
"Installing generic include file ../../../include/fdManager.h"
"Installing generic include file ../../../include/fdmgr.h"
"Installing generic include file ../../../include/flex.skel.static"
"Installing generic include file ../../../include/freeList.h"
"Installing generic include file ../../../include/gpHash.h"
"Installing generic include file ../../../include/iocsh.h"
"Installing generic include file ../../../include/registry.h"
"Installing generic include file ../../../include/libComRegister.h"
"Installing generic include file ../../../include/iocLog.h"
"Installing generic include file ../../../include/logClient.h"
"Installing generic include file ../../../include/macLib.h"
"Installing generic include file ../../../include/alarm.h"
"Installing generic include file ../../../include/alarmString.h"
"Installing generic include file ../../../include/adjustment.h"
"Installing generic include file ../../../include/cantProceed.h"
"Installing generic include file ../../../include/dbDefs.h"
"Installing generic include file ../../../include/epicsConvert.h"
"Installing generic include file ../../../include/epicsExit.h"
"Installing generic include file ../../../include/epicsStdlib.h"
"Installing generic include file ../../../include/epicsString.h"
"Installing generic include file ../../../include/epicsTypes.h"
"Installing generic include file ../../../include/shareLib.h"
"Installing generic include file ../../../include/epicsExport.h"
"Installing generic include file ../../../include/unixFileName.h"
"Installing generic include file ../../../include/locationException.h"
"Installing generic include file ../../../include/ipAddrToAsciiAsynchronous.h"
"Installing generic include file ../../../include/compilerDependencies.h"
"Installing generic include file ../../../include/epicsUnitTest.h"
"Installing generic include file ../../../include/testMain.h"
"Installing generated generic include file ../../../include/epicsVersion.h"
"Installing compiler dependent include file ../../../include/compiler/msvc/compilerSpecific.h"
mkdir ../../../include/compiler
mkdir ../../../include/compiler/msvc
"Installing OS dependent include file ../../../include/os/WIN32/osiFileName.h"
mkdir ../../../include/os
mkdir ../../../include/os/WIN32
"Installing generic include file ../../../include/osiSock.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdSock.h"
"Installing generic include file ../../../include/epicsInterrupt.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdInterrupt.h"
"Installing generic include file ../../../include/epicsMutex.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdMutex.h"
"Installing generic include file ../../../include/epicsSpin.h"
"Installing generic include file ../../../include/epicsEvent.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdEvent.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsMath.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdMessageQueue.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdStrtod.h"
"Installing generic include file ../../../include/epicsAssert.h"
"Installing generic include file ../../../include/epicsFindSymbol.h"
"Installing generic include file ../../../include/osiPoolStatus.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdPoolStatus.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdThread.h"
"Installing generic include file ../../../include/epicsThread.h"
"Installing generic include file ../../../include/epicsTime.h"
"Installing generic include file ../../../include/epicsGeneralTime.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdTime.h"
"Installing generic include file ../../../include/generalTimeSup.h"
"Installing generic include file ../../../include/osiClockTime.h"
"Installing generic include file ../../../include/epicsSignal.h"
"Installing generic include file ../../../include/osiProcess.h"
"Installing OS dependent include file ../../../include/os/WIN32/osiUnistd.h"
"Installing generic include file ../../../include/osiWireFormat.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdWireFormat.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdWireConfig.h"
"Installing generic include file ../../../include/epicsAtomic.h"
"Installing generic include file ../../../include/epicsAtomicDefault.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsAtomicOSD.h"
"Installing compiler dependent include file ../../../include/compiler/msvc/epicsAtomicCD.h"
"Installing generic include file ../../../include/epicsEndian.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsReadline.h"
"Installing generic include file ../../../include/epicsMessageQueue.h"
"Installing generic include file ../../../include/epicsStdio.h"
"Installing generic include file ../../../include/epicsStdioRedirect.h"
"Installing generic include file ../../../include/epicsTempFile.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsGetopt.h"
"Installing generic include file ../../../include/epicsStackTrace.h"
"Installing generic include file ../../../include/devLib.h"
"Installing generic include file ../../../include/devLibVME.h"
"Installing generic include file ../../../include/devLibVMEImpl.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdVME.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsMMIO.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsMMIODef.h"
"Installing generic include file ../../../include/epicsThreadPool.h"
"Installing generic include file ../../../include/epicsRingPointer.h"
"Installing generic include file ../../../include/epicsRingBytes.h"
"Installing generic include file ../../../include/taskwd.h"
"Installing generic include file ../../../include/epicsTimer.h"
"Installing generic include file ../../../include/yajl_common.h"
"Installing generic include file ../../../include/yajl_gen.h"
"Installing generic include file ../../../include/yajl_parse.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsAtomicMS.h"
cl -EHsc -GR -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I
../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../..
/src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/
dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/l
ibCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src
/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../.
./../include/os/WIN32 -I../../../include -c ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
process_begin: CreateProcess(NULL, cl -EHsc -GR -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -T
P -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I
../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src
/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../
../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../.
./../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msv
c -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp, ...) failed.
make (e=2): The system cannot find the file specified.
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m warshall.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
c -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include warshall.d ../../../src/libCom/yacc/warshall.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m verbose.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include verbose.d ../../../src/libCom/yacc/verbose.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m symtab.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include symtab.d ../../../src/libCom/yacc/symtab.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m skeleton.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
c -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include skeleton.d ../../../src/libCom/yacc/skeleton.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m reader.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include reader.d ../../../src/libCom/yacc/reader.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m output.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include output.d ../../../src/libCom/yacc/output.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m mkpar.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/
I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include mkpar.d ../../../src/libCom/yacc/mkpar.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m antelope.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
c -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include antelope.d ../../../src/libCom/yacc/antelope.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m lr0.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/os
i/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/c
ppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../
src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I..
/../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I.
./../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include lr0.d ../../../src/libCom/yacc/lr0.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m lalr.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/o
../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include lalr.d ../../../src/libCom/yacc/lalr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m error.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/
I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include error.d ../../../src/libCom/yacc/error.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m closure.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCo
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include closure.d ../../../src/libCom/yacc/closure.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m iocLogServer.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/
/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include iocLogServer.d ../../../src/libCom/log/iocLogServer.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m tblcmp.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include tblcmp.d ../../../src/libCom/flex/tblcmp.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m sym.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/os
./../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include sym.d ../../../src/libCom/flex/sym.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m nfa.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/os
./../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include nfa.d ../../../src/libCom/flex/nfa.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m misc.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/o
../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include misc.d ../../../src/libCom/flex/misc.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m gen.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/os
./../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include gen.d ../../../src/libCom/flex/gen.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m ecs.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/os
./../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include ecs.d ../../../src/libCom/flex/ecs.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m dfa.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/os
./../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include dfa.d ../../../src/libCom/flex/dfa.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl -m ccl.d -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/os
./../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include ccl.d ../../../src/libCom/flex/ccl.c
make[3]: *** No rule to make target 'epicsTempFile.obj', needed by 'antelope.exe'. Stop.
make[3]: Leaving directory 'c:/base-3.15.2/src/libCom/O.win32-x86'
../../configure/RULES_ARCHS:61: recipe for target 'install.win32-x86' failed
make[2]: *** [install.win32-x86] Error 2
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom'
../configure/RULES_DIRS:88: recipe for target 'libCom.install' failed
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory 'c:/base-3.15.2/src'
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
c:\base-3.15.2>
Sent: Thursday, November 5, 2015 11:36 AM
To: Klyachko, Alexander Vitalievich; [email protected]
Cc: Alexander Klyachko
Subject: RE: Building Epics base 3.15.2 in Windows 7
What version of Visual Studio 2015 are you using (Express, Community, Professional, etc.)? There is a known problem with Express:
http://www.aps.anl.gov/epics/base/R3-15/2-docs/KnownProblems.html
If you not using Express then please send the complete output of the following at the top-level of EPICS base 3.15.2:
make --version
make clean uninstall
make
-----Original Message-----
From: Klyachko, Alexander Vitalievich [mailto:[email protected]]
Sent: Thursday, November 05, 2015 10:14 AM
To: Mark Rivers; [email protected]
Subject: Re: Building Epics base 3.15.2 in Windows 7
Hi Mark,
Thanks for your reply.
I followed the instructions in the link you provided.
I'm using make 4.1, still get the error messages:
_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
Com/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I
../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libC
om/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/l
include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp, ...) failed.
Alex.
Alexander V. Klyachko, Ph.D.
Senior Research Scientist,
Phenix Medical LLC,
120 West 7th St., Suite 313
Bloomington, IN 47404
(812)361-4445
Sent: Wednesday, November 4, 2015 5:20 PM
There was a tech-talk thread about this recently.
http://www.aps.anl.gov/epics/tech-talk/2015/msg01572.php
For 3.15.2 you must use make 4.1. You can find a link to it here:
http://www.aps.anl.gov/epics/base/win32.php
From: [email protected] [[email protected]] on behalf of Klyachko, Alexander Vitalievich [[email protected]]
Sent: Wednesday, November 04, 2015 4:14 PM
To: [email protected]
Subject: Building Epics base 3.15.2 in Windows 7
Hi all,
I'm stuck trying to build Epics base in Windows 7. The system is:
Windows 7 Professional
Epics base-3.15.2
Visual Studio 2015
GnuWin32
Strawberry Perl 5.22
Does anybody know what is going on here?
Alex.
- RE: Building Epics base 3.15.2 in Windows 7 Mark S. Engbretson
- Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
- RE: Building Epics base 3.15.2 in Windows 7 Mark Rivers
- Re: Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
IPAC Driver Version 2.14 Released Andrew Johnson
<2015>
2025
2026
<2015>
2025
2026
