1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building Epics base 3.15.2 in Windows 7
To: "'Mark Rivers'" <[email protected]>, "'Klyachko, Alexander Vitalievich'" <[email protected]>
Cc: [email protected]
Date: Thu, 5 Nov 2015 17:40:46 -0600
For whatever it is worth,  I also use MSVS2010, but did just grab the most
recent tar from March 2015,  that source file does exists in that directory,
but to me, the problem is at the line
process_begin: CreateProcess(NULL
So your version of make might be wrong.
Mark Rivers  has been answering 3.15.2 build questions the last couple of
week by stating that he uses make 4.1.
-----Original Message-----
On Behalf Of Mark Rivers
Sent: Thursday, November 05, 2015 5:10 PM
To: 'Klyachko, Alexander Vitalievich' <[email protected]>
I am not sure what it wrong, perhaps Andrew or someone else has an idea.
I have not tried Visual Studio 2015, I am using 2010.
From: Klyachko, Alexander Vitalievich [mailto:[email protected]]
Sent: Thursday, November 05, 2015 4:39 PM
To: Mark Rivers
Subject: Re: Building Epics base 3.15.2 in Windows 7
I believe VS2015 Professional was downloaded, unfortunately I have no record
of that. I'm pretty sure it is not Express. The output is below.
Thanks much, Alex.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\aklyachk>cd c:\base-3.15.2
c:\base-3.15.2>make --version
GNU Make 4.1
Built for x86_64-w64-mingw32
Copyright (C) 1988-2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
c:\base-3.15.2>make clean uninstall
make -C ./configure clean
make[1]: Entering directory 'c:/base-3.15.2/configure'
perl -CSD -MExtUtils::Command -e rm_rf O.win32-x86 O.Common
make[1]: Leaving directory 'c:/base-3.15.2/configure'
make -C ./src clean
make[1]: Entering directory 'c:/base-3.15.2/src'
make -C ./tools clean
make[2]: Entering directory 'c:/base-3.15.2/src/tools'
make[2]: Leaving directory 'c:/base-3.15.2/src/tools'
make -C tools/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/tools/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/tools/test'
make -C template/base clean
make[2]: Entering directory 'c:/base-3.15.2/src/template/base'
make[2]: Leaving directory 'c:/base-3.15.2/src/template/base'
make -C template/ext clean
make[2]: Entering directory 'c:/base-3.15.2/src/template/ext'
make[2]: Leaving directory 'c:/base-3.15.2/src/template/ext'
make -C ./libCom clean
make[2]: Entering directory 'c:/base-3.15.2/src/libCom'
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom'
make -C libCom/RTEMS clean
make[2]: Entering directory 'c:/base-3.15.2/src/libCom/RTEMS'
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom/RTEMS'
make -C libCom/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/libCom/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/libCom/test'
make -C ca/client clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/client'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/client'
make -C ca/client/tools clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/client/tools'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/client/tools'
make -C ca/legacy/gdd clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/legacy/gdd'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/gdd'
make -C ca/legacy/pcas clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas'
make -C ./build clean
make[3]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas/build'
make[3]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas/build'
make -C ./example clean
make[3]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas/example'
make -C ./directoryService clean
make[4]: Entering directory
'c:/base-3.15.2/src/ca/legacy/pcas/example/directoryService'
make[4]: Leaving directory
make[3]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas/example'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas'
make -C ./ioc clean
make[2]: Entering directory 'c:/base-3.15.2/src/ioc'
make[2]: Leaving directory 'c:/base-3.15.2/src/ioc'
make -C ca/legacy/pcas/ex clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/legacy/pcas/ex'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/legacy/pcas/ex'
make -C ca/client/perl clean
make[2]: Entering directory 'c:/base-3.15.2/src/ca/client/perl'
make[2]: Leaving directory 'c:/base-3.15.2/src/ca/client/perl'
make -C ioc/db/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/ioc/db/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/ioc/db/test'
make -C ioc/dbtemplate/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/ioc/dbtemplate/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/ioc/dbtemplate/test'
make -C ./std clean
make[2]: Entering directory 'c:/base-3.15.2/src/std'
make[2]: Leaving directory 'c:/base-3.15.2/src/std'
make -C std/filters/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/std/filters/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/std/filters/test'
make -C std/rec/test clean
make[2]: Entering directory 'c:/base-3.15.2/src/std/rec/test'
make[2]: Leaving directory 'c:/base-3.15.2/src/std/rec/test'
make[1]: Leaving directory 'c:/base-3.15.2/src'
perl -CSD -MExtUtils::Command -e rm_rf ./bin/win32-x86
perl -CSD -MExtUtils::Command -e rm_rf ./lib/win32-x86
perl -CSD -MExtUtils::Command -e rm_rf ./dbd ./include ./doc ./html
./templates ./db ./adl ./alh ./cfg ./edl ./lib/perl ./lib/pkgconfig
c:\base-3.15.2>make
make -C ./configure install
perl -CSD ../src/tools/makeMakefile.pl O.win32-x86 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../.. \
    T_A=win32-x86 install
make[2]: Entering directory 'c:/base-3.15.2/configure/O.win32-x86'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'c:/base-3.15.2/configure/O.win32-x86'
make -C ./src install
make -C ./tools install
perl -CSD ../../src/tools/makeMakefile.pl O.win32-x86 ../../..
make -C O.win32-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'c:/base-3.15.2/src/tools/O.win32-x86'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/macLib.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Base.pm"
mkdir ../../../lib/perl/DBD
"Installing PERL_MODULES file ../../../lib/perl/DBD/Breaktable.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Device.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Driver.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Function.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Menu.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Output.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Parser.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recfield.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recordtype.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Registrar.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Variable.pm"
"Expanding epics-base-win32-x86.pc@ to epics-base-win32-x86.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-win32-x86.pc"
mkdir ../../../lib/pkgconfig
"Expanding ../epics-base.pc@ to epics-base.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base.pc"
"Installing created executable ../../../bin/win32-x86/convertRelease.pl"
mkdir ../../../bin/win32-x86
"Installing created executable ../../../bin/win32-x86/cvsclean.pl"
"Installing created executable ../../../bin/win32-x86/dos2unix.pl"
"Installing created executable ../../../bin/win32-x86/expandVars.pl"
"Installing created executable ../../../bin/win32-x86/fullPathName.pl"
"Installing created executable ../../../bin/win32-x86/installEpics.pl"
"Installing created executable ../../../bin/win32-x86/makeIncludeDbd.pl"
"Installing created executable ../../../bin/win32-x86/makeMakefile.pl"
"Installing created executable ../../../bin/win32-x86/makeTestfile.pl"
"Installing created executable ../../../bin/win32-x86/mkmf.pl"
"Installing created executable ../../../bin/win32-x86/munch.pl"
"Installing created executable ../../../bin/win32-x86/replaceVAR.pl"
"Installing created executable ../../../bin/win32-x86/useManifestTool.pl"
"Installing created executable ../../../bin/win32-x86/dbdToMenuH.pl"
"Installing created executable ../../../bin/win32-x86/dbdToRecordtypeH.pl"
"Installing created executable ../../../bin/win32-x86/dbdExpand.pl"
"Installing created executable ../../../bin/win32-x86/dbdToHtml.pl"
"Installing created executable ../../../bin/win32-x86/podToHtml.pl"
"Installing created executable ../../../bin/win32-x86/podRemove.pl"
../../../bin/win32-x86/registerRecordDeviceDriver.pl"
"Installing html ../../../html/./style.css"
mkdir ../../../html
mkdir ../../../html/.
make[3]: Leaving directory 'c:/base-3.15.2/src/tools/O.win32-x86'
make -C tools/test install
perl -CSD c:/base-3.15.2/bin/win32-x86/makeMakefile.pl O.win32-x86
make -C O.win32-x86 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory 'c:/base-3.15.2/src/tools/test/O.win32-x86'
perl -CSD -MExtUtils::Command -e cp ../Breaktable.plt Breaktable.t
perl -CSD -MExtUtils::Command -e cp ../DBD.plt DBD.t
perl -CSD -MExtUtils::Command -e cp ../Device.plt Device.t
perl -CSD -MExtUtils::Command -e cp ../Driver.plt Driver.t
perl -CSD -MExtUtils::Command -e cp ../Function.plt Function.t
perl -CSD -MExtUtils::Command -e cp ../macLib.plt macLib.t
perl -CSD -MExtUtils::Command -e cp ../Menu.plt Menu.t
perl -CSD -MExtUtils::Command -e cp ../Recfield.plt Recfield.t
perl -CSD -MExtUtils::Command -e cp ../Recordtype.plt Recordtype.t
perl -CSD -MExtUtils::Command -e cp ../Registrar.plt Registrar.t
perl -CSD -MExtUtils::Command -e cp ../Variable.plt Variable.t
make[3]: Leaving directory 'c:/base-3.15.2/src/tools/test/O.win32-x86'
make -C template/base install
make[3]: Entering directory 'c:/base-3.15.2/src/template/base/O.win32-x86'
"Installing created executable ../../../../bin/win32-x86/makeBaseApp.pl"
"Installing ../../../../templates/makeBaseApp/top/Makefile"
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseApp/top/configure
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseApp/top/configure/Makefile"
"Installing ../../../../templates/makeBaseApp/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseApp/top/supportApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp
"Installing ../../../../templates/makeBaseApp/top/supportApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp/Db
"Installing ../../../../templates/makeBaseApp/top/supportApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/supportApp/src
"Installing
../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd"
"Installing ../../../../templates/makeBaseApp/top/iocApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp
"Installing ../../../../templates/makeBaseApp/top/iocApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp/Db
"Installing ../../../../templates/makeBaseApp/top/iocApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocApp/src
"Installing
../../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp
"Installing ../../../../templates/makeBaseApp/top/exampleApp/Db/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp/Db
"Installing
../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions"
"Installing ../../../../templates/makeBaseApp/top/exampleApp/src/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleApp/src
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c"
"Installing
../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd"
"Installing ../../../../templates/makeBaseApp/top/exampleBoot/Makefile"
mkdir ../../../../templates/makeBaseApp/top/exampleBoot
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common"
mkdir ../../../../templates/makeBaseApp/top/exampleBoot/ioc
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@windows"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@cygwin"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common"
"Installing
../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/caClientApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/caClientApp
"Installing ../../../../templates/makeBaseApp/top/caClientApp/caExample.c"
"Installing ../../../../templates/makeBaseApp/top/caClientApp/caMonitor.c"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/Makefile"
mkdir ../../../../templates/makeBaseApp/top/caServerApp
"Installing ../../../../templates/makeBaseApp/top/caServerApp/README"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exChannel.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exServer.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exServer.h"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/main.cc"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/test.adl"
"Installing ../../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/Makefile"
mkdir ../../../../templates/makeBaseApp/top/iocBoot
"Installing
../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS"
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common"
mkdir ../../../../templates/makeBaseApp/top/iocBoot/ioc
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks"
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32"
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@windows"
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@cygwin"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross"
"Installing
../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks"
"Installing ../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS"
make[3]: Leaving directory 'c:/base-3.15.2/src/template/base/O.win32-x86'
make -C template/ext install
make[3]: Entering directory 'c:/base-3.15.2/src/template/ext/O.win32-x86'
"Installing created executable ../../../../bin/win32-x86/makeBaseExt.pl"
"Installing ../../../../templates/makeBaseExt/top/Makefile"
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
"Installing ../../../../templates/makeBaseExt/top/README"
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseExt/top/configure
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseExt/top/configure/Makefile"
"Installing ../../../../templates/makeBaseExt/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-p
pc"
mkdir ../../../../templates/makeBaseExt/top/configure/os
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc
64-gnu.solaris-sparc64-gnu"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_6
4.freebsd-x86_64"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.da
rwin-x86"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-38
6"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cy
gwin-x86"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_6
4.solaris-x86_64"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.lin
ux-ppc"
"Installing
-debug.solaris-sparc-debug"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.w
indows-x64"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-deb
ug.win32-x86-debug"
"Installing
.solaris-sparc"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win
32-x86"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-deb
ug.linux-x86-debug"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cyg
win.win32-x86-cygwin"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.lin
ux-x86"
"Installing
64.solaris-sparc64"
"Installing
-gnu.solaris-sparc-gnu"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86
.darwin-ppcx86"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-d
ebug.solaris-x86-debug"
"Installing
ux-athlon"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.s
olaris-x86"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-g
nu.solaris-x86-gnu"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.a
ix-ppc-gnu"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-
debug.linux-x86_64-debug"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-min
gw.win32-x86-mingw"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.
linux-x86_64"
"Installing
../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.da
rwin-ppc"
"Installing ../../../../templates/makeBaseExt/top/src/Makefile"
mkdir ../../../../templates/makeBaseExt/top/src
"Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/exampleExt
"Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c"
"Installing
../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM"
"Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory 'c:/base-3.15.2/src/template/ext/O.win32-x86'
make -C ./libCom install
perl -CSD c:/base-3.15.2/bin/win32-x86/makeMakefile.pl O.win32-x86 ../../..
make[3]: Entering directory 'c:/base-3.15.2/src/libCom/O.win32-x86'
perl -CSD ../../../src/libCom/misc/makeEpicsVersion.pl -o epicsVersion.h
../../../configure/CONFIG_BASE_VERSION
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 3.15.2
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m forceBadAllocException.d
-I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc
-I../../../src/libCom/osi/compiler/default -I. -I../
../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
-I../../../src/libCom/as -I../../../src/libCom/bucketLib
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I..
/../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCo
m/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList
-I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../s
rc/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool
-I../../../src/libCom/ring -I../../../src/libCom/taskwd
-I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../
src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc
-I../../../include/os/WIN32 -I../../../include
forceBadAllocException.d ../../../src/libCom/osi/os/WIN32/f
orceBadAllocException.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m setThreadName.d -I.
-I../../../src/libCom/osi/compiler/default -I. -I../../../src
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../sr
-I../../../src/libCom/fdmgr -
-I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom
-I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCo
-I../../../include/os/WIN32 -I../../../include         setThreadName.d
../../../src/libCom/osi/os/WIN32/setThreadName.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsGetopt.d -I.
-I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/
libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf
-I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../../src/libCom/error -I../../../src/libCom/fdmgr -I.
-I../../../include/os/WIN32 -I../../../include         epicsGetopt.d
../../../src/libCom/osi/os/WIN32/epicsGetopt.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m yajl_parser.d -I.
-I../../../include/os/WIN32 -I../../../include         yajl_parser.d
../../../src/libCom/yajl/yajl_parser.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m yajl_lex.d -I.
-I../../../src/libCom/osi/compiler/default -I. -I../../../src/libC
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/lib
-I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../.
-I../../../src/libCom/misc
-I../../../include/os/WIN32 -I../../../include         yajl_lex.d
../../../src/libCom/yajl/yajl_lex.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m yajl_gen.d -I.
-I../../../include/os/WIN32 -I../../../include         yajl_gen.d
../../../src/libCom/yajl/yajl_gen.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m yajl_encode.d -I.
-I../../../include/os/WIN32 -I../../../include         yajl_encode.d
../../../src/libCom/yajl/yajl_encode.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m yajl_buf.d -I.
-I../../../include/os/WIN32 -I../../../include         yajl_buf.d
../../../src/libCom/yajl/yajl_buf.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m yajl_alloc.d -I.
-I../../../include/os/WIN32 -I../../../include         yajl_alloc.d
../../../src/libCom/yajl/yajl_alloc.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m yajl.d -I. -I../O.Common
-I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/o
-I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../..
/src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash
-I../../../src/libCom/iocsh -I../../../src/libCom/log
-I../../../src/libCom/macLib -I../../../src/libCom/misc -I.
./../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring
-I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/yacc -I../../../src/libCom/yacc -I
-I../../../include/os/WIN32 -I../../../include         yajl.d
../../../src/libCom/yajl/yajl.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m timerQueuePassive.d -I.
-I../../../include/os/WIN32 -I../../../include         timerQueuePassive.d
../../../src/libCom/timer/timerQueuePassive.
cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m timerQueueActiveMgr.d -I.
-I../../../include/os/WIN32 -I../../../include         timerQueueActiveMgr.d
../../../src/libCom/timer/timerQueueActi
veMgr.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m timerQueueActive.d -I.
-I../../../include/os/WIN32 -I../../../include         timerQueueActive.d
../../../src/libCom/timer/timerQueueActive.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m timerQueue.d -I.
-I../../../include/os/WIN32 -I../../../include         timerQueue.d
../../../src/libCom/timer/timerQueue.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m timer.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         timer.d
../../../src/libCom/timer/timer.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsTimer.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsTimer.d
../../../src/libCom/timer/epicsTimer.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m taskwd.d -I.
-I../../../include/os/WIN32 -I../../../include         taskwd.d
../../../src/libCom/taskwd/taskwd.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsRingBytes.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsRingBytes.d
../../../src/libCom/ring/epicsRingBytes.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsRingPointer.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsRingPointer.d
../../../src/libCom/ring/epicsRingPointer.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m threadPool.d -I.
-I../../../include/os/WIN32 -I../../../include         threadPool.d
../../../src/libCom/pool/threadPool.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m poolJob.d -I.
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libC
-I../../../include/os/WIN32 -I../../../include         poolJob.d
../../../src/libCom/pool/poolJob.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdFindAddr.d -I.
-I../../../include/os/WIN32 -I../../../include         osdFindAddr.d
../../../src/libCom/osi/os/default/osdFindAddr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdBackTrace.d -I.
/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf
-I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom
-I../../../include/os/WIN32 -I../../../include         osdBackTrace.d
../../../src/libCom/osi/os/WIN32/osdBackTrace.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsStackTrace.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsStackTrace.d
../../../src/libCom/osi/epicsStackTrace.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m devLibVMEOSD.d -I.
-I../../../include/os/WIN32 -I../../../include         devLibVMEOSD.d
../../../src/libCom/osi/os/default/devLibVMEOSD.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m devLibVME.d -I.
-I../../../include/os/WIN32 -I../../../include         devLibVME.d
../../../src/libCom/osi/devLibVME.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdMessageQueue.d -I.
-I../../../include/os/WIN32 -I../../../include         osdMessageQueue.d
../../../src/libCom/osi/os/default/osdMessageQue
ue.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdNetIntf.d -I.
-I../../../include/os/WIN32 -I../../../include         osdNetIntf.d
../../../src/libCom/osi/os/WIN32/osdNetIntf.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdProcess.d -I.
-I../../../include/os/WIN32 -I../../../include         osdProcess.d
../../../src/libCom/osi/os/WIN32/osdProcess.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdTime.d -I.
-I../../../include/os/WIN32 -I../../../include         osdTime.d
../../../src/libCom/osi/os/WIN32/osdTime.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdEvent.d -I.
-I../../../include/os/WIN32 -I../../../include         osdEvent.d
../../../src/libCom/osi/os/WIN32/osdEvent.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdSpin.d -I.
-I../../../include/os/WIN32 -I../../../include         osdSpin.d
../../../src/libCom/osi/os/default/osdSpin.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdMutex.d -I.
-I../../../include/os/WIN32 -I../../../include         osdMutex.d
../../../src/libCom/osi/os/WIN32/osdMutex.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdThreadHooks.d -I.
-I../../../include/os/WIN32 -I../../../include         osdThreadHooks.d
../../../src/libCom/osi/os/default/osdThreadHooks.
c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdThreadExtra.d -I.
-I../../../include/os/WIN32 -I../../../include         osdThreadExtra.d
../../../src/libCom/osi/os/WIN32/osdThreadExtra.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdThread.d -I.
-I../../../include/os/WIN32 -I../../../include         osdThread.d
../../../src/libCom/osi/os/WIN32/osdThread.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdStdio.d -I.
-I../../../include/os/WIN32 -I../../../include         osdStdio.d
../../../src/libCom/osi/os/WIN32/osdStdio.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsStdio.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsStdio.d
../../../src/libCom/osi/epicsStdio.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsTempFile.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsTempFile.d
../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsReadline.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsReadline.d
../../../src/libCom/osi/os/default/epicsReadline.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdEnv.d -I.
-I../../../include/os/WIN32 -I../../../include         osdEnv.d
../../../src/libCom/osi/os/default/osdEnv.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdSignal.d -I.
-I../../../include/os/WIN32 -I../../../include         osdSignal.d
../../../src/libCom/osi/os/WIN32/osdSignal.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdPoolStatus.d -I.
-I../../../include/os/WIN32 -I../../../include         osdPoolStatus.d
../../../src/libCom/osi/os/WIN32/osdPoolStatus.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdInterrupt.d -I.
-I../../../include/os/WIN32 -I../../../include         osdInterrupt.d
../../../src/libCom/osi/os/default/osdInterrupt.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdFindSymbol.d -I.
-I../../../include/os/WIN32 -I../../../include         osdFindSymbol.d
../../../src/libCom/osi/os/WIN32/osdFindSymbol.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdAssert.d -I.
-I../../../include/os/WIN32 -I../../../include         osdAssert.d
../../../src/libCom/osi/os/default/osdAssert.c
epicsSocketConvertErrnoToString.d -I. -I../O.Common -I.
-I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
-I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib
Fast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList
./../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool
../../../src/libCom/yacc -I../../../src/libCom/yajl
-I../../../include/compiler/msvc -I../../../include/os/WIN32
-I../../../include         epicsSocketConvertErrnoToString.d
../../../src/lib
Com/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m systemCallIntMech.d -I.
-I../../../include/os/WIN32 -I../../../include         systemCallIntMech.d
../../../src/libCom/osi/os/WIN32/systemCallI
ntMech.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osiSock.d -I.
-I../../../include/os/WIN32 -I../../../include         osiSock.d
../../../src/libCom/osi/osiSock.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdSockAddrReuse.d -I.
-I../../../include/os/WIN32 -I../../../include         osdSockAddrReuse.d
../../../src/libCom/osi/os/WIN32/osdSockAddrRe
use.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osdSock.d -I.
-I../../../include/os/WIN32 -I../../../include         osdSock.d
../../../src/libCom/osi/os/WIN32/osdSock.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m osiClockTime.d -I.
-I../../../include/os/WIN32 -I../../../include         osiClockTime.d
../../../src/libCom/osi/osiClockTime.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsGeneralTime.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsGeneralTime.d
../../../src/libCom/osi/epicsGeneralTime.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsAtomicOSD.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsAtomicOSD.d
../../../src/libCom/osi/os/default/epicsAtomicOSD.
cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsMath.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsMath.d
../../../src/libCom/osi/epicsMath.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsMessageQueue.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsMessageQueue.d
../../../src/libCom/osi/epicsMessageQueue.cp
p
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsTime.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsTime.d
../../../src/libCom/osi/epicsTime.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsEvent.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsEvent.d
../../../src/libCom/osi/epicsEvent.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsMutex.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsMutex.d
../../../src/libCom/osi/epicsMutex.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsThread.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsThread.d
../../../src/libCom/osi/epicsThread.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsUnitTest.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsUnitTest.d
../../../src/libCom/misc/epicsUnitTest.c
ipAddrToAsciiAsynchronous.d -I. -I../O.Common -I.
../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
-I../../../include         ipAddrToAsciiAsynchronous.d
../../../src/libCom/misc/ipA
ddrToAsciiAsynchronous.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m truncateFile.d -I.
-I../../../include/os/WIN32 -I../../../include         truncateFile.d
../../../src/libCom/misc/truncateFile.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsString.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsString.d
../../../src/libCom/misc/epicsString.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsStdlib.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsStdlib.d
../../../src/libCom/misc/epicsStdlib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsExit.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsExit.d
../../../src/libCom/misc/epicsExit.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsConvert.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsConvert.d
../../../src/libCom/misc/epicsConvert.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m cantProceed.d -I.
-I../../../include/os/WIN32 -I../../../include         cantProceed.d
../../../src/libCom/misc/cantProceed.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m adjustment.d -I.
-I../../../include/os/WIN32 -I../../../include         adjustment.d
../../../src/libCom/misc/adjustment.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m aToIPAddr.d -I.
-I../../../include/os/WIN32 -I../../../include         aToIPAddr.d
../../../src/libCom/misc/aToIPAddr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m alarmString.d -I.
-I../../../include/os/WIN32 -I../../../include         alarmString.d
../../../src/libCom/misc/alarmString.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m macUtil.d -I.
-I../../../include/os/WIN32 -I../../../include         macUtil.d
../../../src/libCom/macLib/macUtil.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m macEnv.d -I.
-I../../../include/os/WIN32 -I../../../include         macEnv.d
../../../src/libCom/macLib/macEnv.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m macCore.d -I.
-I../../../include/os/WIN32 -I../../../include         macCore.d
../../../src/libCom/macLib/macCore.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m logClient.d -I.
-I../../../include/os/WIN32 -I../../../include         logClient.d
../../../src/libCom/log/logClient.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m iocLog.d -I.
-I../../../include/os/WIN32 -I../../../include         iocLog.d
../../../src/libCom/log/iocLog.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m libComRegister.d -I.
-I../../../include/os/WIN32 -I../../../include         libComRegister.d
../../../src/libCom/iocsh/libComRegister.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m registry.d -I.
-I../../../include/os/WIN32 -I../../../include         registry.d
../../../src/libCom/iocsh/registry.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m iocsh.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         iocsh.d
../../../src/libCom/iocsh/iocsh.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m gpHashLib.d -I.
-I../../../include/os/WIN32 -I../../../include         gpHashLib.d
../../../src/libCom/gpHash/gpHashLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m freeListLib.d -I.
-I../../../include/os/WIN32 -I../../../include         freeListLib.d
../../../src/libCom/freeList/freeListLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m fdManager.d -I.
-I../../../include/os/WIN32 -I../../../include         fdManager.d
../../../src/libCom/fdmgr/fdManager.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m fdmgr.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         fdmgr.d
../../../src/libCom/fdmgr/fdmgr.cpp
perl -CSD ../../../src/libCom/error/makeStatTbl.pl
../../../src/libCom/osi/devLib.h ../../../src/libCom/as/asLib.h
../../../src/libCom/misc/epicsStdlib.h ../../../src/libCom/pool/epicsThrea
dPool.h ../../../src/ioc/db/dbAccessDefs.h
../../../src/ioc/dbStatic/devSup.h ../../../src/ioc/dbStatic/drvSup.h
../../../src/ioc/dbStatic/recSup.h ../../../src/ioc/dbStatic/dbStaticLib.h
/../../src/libCom/error/errMdef.h
../../../src/ca/legacy/pcas/generic/casdef.h
../../../src/ca/legacy/gdd/gddAppFuncTable.h
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m errSymTbl.d -I.
-I../../../include/os/WIN32 -I../../../include         errSymTbl.d
errSymTbl.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m errSymLib.d -I.
-I../../../include/os/WIN32 -I../../../include         errSymLib.d
../../../src/libCom/error/errSymLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m errlog.d -I.
-I../../../include/os/WIN32 -I../../../include         errlog.d
../../../src/libCom/error/errlog.c
perl -CSD ../../../src/libCom/env/bldEnvData.pl  ../../../configure
Generating envData.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m envData.d -I.
-I../../../include/os/WIN32 -I../../../include         envData.d envData.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m envSubr.d -I.
-I../../../include/os/WIN32 -I../../../include         envSubr.d
../../../src/libCom/env/envSubr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m ellLib.d -I.
-I../../../include/os/WIN32 -I../../../include         ellLib.d
../../../src/libCom/ellLib/ellLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m dbmf.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         dbmf.d
../../../src/libCom/dbmf/dbmf.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsSingletonMutex.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsSingletonMutex.d
../../../src/libCom/cxxTemplates/epicsSi
ngletonMutex.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m epicsOnce.d -I.
-I../../../include/os/WIN32 -I../../../include         epicsOnce.d
../../../src/libCom/cxxTemplates/epicsOnce.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m resourceLib.d -I.
-I../../../include/os/WIN32 -I../../../include         resourceLib.d
../../../src/libCom/cxxTemplates/resourceLib.cpp
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m cvtFast.d -I.
-I../../../include/os/WIN32 -I../../../include         cvtFast.d
../../../src/libCom/cvtFast/cvtFast.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m calcPerform.d -I.
-I../../../include/os/WIN32 -I../../../include         calcPerform.d
../../../src/libCom/calc/calcPerform.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m postfix.d -I.
-I../../../include/os/WIN32 -I../../../include         postfix.d
../../../src/libCom/calc/postfix.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m bucketLib.d -I.
-I../../../include/os/WIN32 -I../../../include         bucketLib.d
../../../src/libCom/bucketLib/bucketLib.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m asTrapWrite.d -I.
-I../../../include/os/WIN32 -I../../../include         asTrapWrite.d
../../../src/libCom/as/asTrapWrite.c
"Installing generic include file ../../../include/asLib.h"
mkdir ../../../include
"Installing generic include file ../../../include/asTrapWrite.h"
"Installing generic include file ../../../include/bucketLib.h"
"Installing generic include file ../../../include/postfix.h"
"Installing generic include file ../../../include/cvtFast.h"
"Installing generic include file ../../../include/epicsAlgorithm.h"
"Installing generic include file ../../../include/epicsExcept.h"
"Installing generic include file ../../../include/epicsMemory.h"
"Installing generic include file ../../../include/resourceLib.h"
"Installing generic include file ../../../include/tsDLList.h"
"Installing generic include file ../../../include/tsSLList.h"
"Installing generic include file ../../../include/tsMinMax.h"
"Installing generic include file ../../../include/tsBTree.h"
"Installing generic include file ../../../include/tsFreeList.h"
"Installing generic include file ../../../include/epicsSingleton.h"
"Installing generic include file ../../../include/epicsGuard.h"
"Installing generic include file ../../../include/epicsOnce.h"
"Installing generic include file ../../../include/dbmf.h"
"Installing generic include file ../../../include/ellLib.h"
"Installing generic include file ../../../include/envDefs.h"
"Installing generic include file ../../../include/epicsPrint.h"
"Installing generic include file ../../../include/errMdef.h"
"Installing generic include file ../../../include/errSymTbl.h"
"Installing generic include file ../../../include/errlog.h"
"Installing generic include file ../../../include/error.h"
"Installing generic include file ../../../include/fdManager.h"
"Installing generic include file ../../../include/fdmgr.h"
"Installing generic include file ../../../include/flex.skel.static"
"Installing generic include file ../../../include/freeList.h"
"Installing generic include file ../../../include/gpHash.h"
"Installing generic include file ../../../include/iocsh.h"
"Installing generic include file ../../../include/registry.h"
"Installing generic include file ../../../include/libComRegister.h"
"Installing generic include file ../../../include/iocLog.h"
"Installing generic include file ../../../include/logClient.h"
"Installing generic include file ../../../include/macLib.h"
"Installing generic include file ../../../include/alarm.h"
"Installing generic include file ../../../include/alarmString.h"
"Installing generic include file ../../../include/adjustment.h"
"Installing generic include file ../../../include/cantProceed.h"
"Installing generic include file ../../../include/dbDefs.h"
"Installing generic include file ../../../include/epicsConvert.h"
"Installing generic include file ../../../include/epicsExit.h"
"Installing generic include file ../../../include/epicsStdlib.h"
"Installing generic include file ../../../include/epicsString.h"
"Installing generic include file ../../../include/epicsTypes.h"
"Installing generic include file ../../../include/shareLib.h"
"Installing generic include file ../../../include/epicsExport.h"
"Installing generic include file ../../../include/unixFileName.h"
"Installing generic include file ../../../include/locationException.h"
../../../include/ipAddrToAsciiAsynchronous.h"
"Installing generic include file ../../../include/compilerDependencies.h"
"Installing generic include file ../../../include/epicsUnitTest.h"
"Installing generic include file ../../../include/testMain.h"
"Installing generated generic include file ../../../include/epicsVersion.h"
"Installing compiler dependent include file
../../../include/compiler/msvc/compilerSpecific.h"
mkdir ../../../include/compiler
mkdir ../../../include/compiler/msvc
"Installing OS dependent include file
../../../include/os/WIN32/osiFileName.h"
mkdir ../../../include/os
mkdir ../../../include/os/WIN32
"Installing generic include file ../../../include/osiSock.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdSock.h"
"Installing generic include file ../../../include/epicsInterrupt.h"
../../../include/os/WIN32/osdInterrupt.h"
"Installing generic include file ../../../include/epicsMutex.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdMutex.h"
"Installing generic include file ../../../include/epicsSpin.h"
"Installing generic include file ../../../include/epicsEvent.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdEvent.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsMath.h"
../../../include/os/WIN32/osdMessageQueue.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdStrtod.h"
"Installing generic include file ../../../include/epicsAssert.h"
"Installing generic include file ../../../include/epicsFindSymbol.h"
"Installing generic include file ../../../include/osiPoolStatus.h"
../../../include/os/WIN32/osdPoolStatus.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdThread.h"
"Installing generic include file ../../../include/epicsThread.h"
"Installing generic include file ../../../include/epicsTime.h"
"Installing generic include file ../../../include/epicsGeneralTime.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdTime.h"
"Installing generic include file ../../../include/generalTimeSup.h"
"Installing generic include file ../../../include/osiClockTime.h"
"Installing generic include file ../../../include/epicsSignal.h"
"Installing generic include file ../../../include/osiProcess.h"
"Installing OS dependent include file ../../../include/os/WIN32/osiUnistd.h"
"Installing generic include file ../../../include/osiWireFormat.h"
../../../include/os/WIN32/osdWireFormat.h"
../../../include/os/WIN32/osdWireConfig.h"
"Installing generic include file ../../../include/epicsAtomic.h"
"Installing generic include file ../../../include/epicsAtomicDefault.h"
../../../include/os/WIN32/epicsAtomicOSD.h"
../../../include/compiler/msvc/epicsAtomicCD.h"
"Installing generic include file ../../../include/epicsEndian.h"
../../../include/os/WIN32/epicsReadline.h"
"Installing generic include file ../../../include/epicsMessageQueue.h"
"Installing generic include file ../../../include/epicsStdio.h"
"Installing generic include file ../../../include/epicsStdioRedirect.h"
"Installing generic include file ../../../include/epicsTempFile.h"
../../../include/os/WIN32/epicsGetopt.h"
"Installing generic include file ../../../include/epicsStackTrace.h"
"Installing generic include file ../../../include/devLib.h"
"Installing generic include file ../../../include/devLibVME.h"
"Installing generic include file ../../../include/devLibVMEImpl.h"
"Installing OS dependent include file ../../../include/os/WIN32/osdVME.h"
"Installing OS dependent include file ../../../include/os/WIN32/epicsMMIO.h"
../../../include/os/WIN32/epicsMMIODef.h"
"Installing generic include file ../../../include/epicsThreadPool.h"
"Installing generic include file ../../../include/epicsRingPointer.h"
"Installing generic include file ../../../include/epicsRingBytes.h"
"Installing generic include file ../../../include/taskwd.h"
"Installing generic include file ../../../include/epicsTimer.h"
"Installing generic include file ../../../include/yajl_common.h"
"Installing generic include file ../../../include/yajl_gen.h"
"Installing generic include file ../../../include/yajl_parse.h"
../../../include/os/WIN32/epicsAtomicMS.h"
cl -EHsc -GR                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
-D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355        -MD
-DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I
-I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I..
-I../../..
/src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc
-I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd
dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/l
ibCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log
-I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src
/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../.
./../include/os/WIN32 -I../../../include         -c
process_begin: CreateProcess(NULL, cl -EHsc -GR -nologo -D__STDC__=0
-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3
-w44355 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -T
P -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc
-I
-I../../../src
/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env
../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log
-I../../../src/libCom/yacc -I../../../src/libCom/yajl
c -I../../../include/os/WIN32 -I../../../include -c
../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp, ...) failed.
make (e=2): The system cannot find the file specified.
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m warshall.d -I.
-I../../../include/os/WIN32 -I../../../include         warshall.d
../../../src/libCom/yacc/warshall.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m verbose.d -I.
-I../../../include/os/WIN32 -I../../../include         verbose.d
../../../src/libCom/yacc/verbose.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m symtab.d -I.
-I../../../include/os/WIN32 -I../../../include         symtab.d
../../../src/libCom/yacc/symtab.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m skeleton.d -I.
-I../../../include/os/WIN32 -I../../../include         skeleton.d
../../../src/libCom/yacc/skeleton.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m reader.d -I.
-I../../../include/os/WIN32 -I../../../include         reader.d
../../../src/libCom/yacc/reader.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m output.d -I.
-I../../../include/os/WIN32 -I../../../include         output.d
../../../src/libCom/yacc/output.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m mkpar.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         mkpar.d
../../../src/libCom/yacc/mkpar.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m antelope.d -I.
-I../../../include/os/WIN32 -I../../../include         antelope.d
../../../src/libCom/yacc/antelope.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m lr0.d -I. -I../O.Common
-I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/os
-I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../
-I../../../src/libCom/macLib -I../../../src/libCom/misc -I..
-I../../../src/libCom/yacc -I../../../src/libCom/yacc -I.
-I../../../include/os/WIN32 -I../../../include         lr0.d
../../../src/libCom/yacc/lr0.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m lalr.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         lalr.d
../../../src/libCom/yacc/lalr.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m error.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         error.d
../../../src/libCom/yacc/error.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m closure.d -I.
-I../../../include/os/WIN32 -I../../../include         closure.d
../../../src/libCom/yacc/closure.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m iocLogServer.d -I.
-I../../../include/os/WIN32 -I../../../include         iocLogServer.d
../../../src/libCom/log/iocLogServer.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m tblcmp.d -I.
-I../../../include/os/WIN32 -I../../../include         tblcmp.d
../../../src/libCom/flex/tblcmp.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m sym.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         sym.d
../../../src/libCom/flex/sym.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m nfa.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         nfa.d
../../../src/libCom/flex/nfa.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m misc.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         misc.d
../../../src/libCom/flex/misc.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m gen.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         gen.d
../../../src/libCom/flex/gen.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m ecs.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         ecs.d
../../../src/libCom/flex/ecs.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m dfa.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         dfa.d
../../../src/libCom/flex/dfa.c
perl -CSD c:/base-3.15.2/bin/win32-x86/mkmf.pl  -m ccl.d -I. -I../O.Common
-I../../../include/os/WIN32 -I../../../include         ccl.d
../../../src/libCom/flex/ccl.c
-I../../..
-I
-I../../../src
make[3]: *** No rule to make target 'epicsTempFile.obj', needed by
'antelope.exe'.  Stop.
make[3]: Leaving directory 'c:/base-3.15.2/src/libCom/O.win32-x86'
../../configure/RULES_ARCHS:61: recipe for target 'install.win32-x86' failed
make[2]: *** [install.win32-x86] Error 2
../configure/RULES_DIRS:88: recipe for target 'libCom.install' failed
make[1]: *** [libCom.install] Error 2
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
c:\base-3.15.2>
Sent: Thursday, November 5, 2015 11:36 AM
To: Klyachko, Alexander Vitalievich; [email protected]
Cc: Alexander Klyachko
What version of Visual Studio 2015 are you using (Express, Community,
Professional, etc.)?  There is a known problem with Express:
http://www.aps.anl.gov/epics/base/R3-15/2-docs/KnownProblems.html
If you not using Express then please send the complete output of the
following at the top-level of EPICS base 3.15.2:
make --version
make
Sent: Thursday, November 05, 2015 10:14 AM
To: Mark Rivers; [email protected]
Hi Mark,
Thanks for your reply.
I followed the instructions in the link you provided.
I'm using make 4.1, still get the error messages:
-w44355 -MD -DEPICS
_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I.
Com/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
om/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib
-I../../../src/libCom/misc -I../../../src/libCom/osi
include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c
Alex.
 Alexander V. Klyachko, Ph.D.
Senior Research Scientist,
Phenix Medical LLC,
120 West 7th St., Suite 313
Bloomington, IN 47404
(812)361-4445
Sent: Wednesday, November 4, 2015 5:20 PM
There was a tech-talk thread about this recently.
http://www.aps.anl.gov/epics/tech-talk/2015/msg01572.php
For 3.15.2 you must use make 4.1.  You can find a link to it here:
http://www.aps.anl.gov/epics/base/win32.php
behalf of Klyachko, Alexander Vitalievich [[email protected]]
Sent: Wednesday, November 04, 2015 4:14 PM
To: [email protected]
Subject: Building Epics base 3.15.2 in Windows 7
Hi all,
I'm stuck trying to build Epics base in Windows 7. The system is:
Windows 7 Professional
Epics base-3.15.2
Visual Studio 2015
GnuWin32
Strawberry Perl 5.22
Does anybody know what is going on here?
Alex.
-w44355 -MD -DEPICS
-w44355 -MD -DEPICS
Re: Building Epics base 3.15.2 in Windows 7 Andrew Johnson
Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
RE: Building Epics base 3.15.2 in Windows 7 Mark Rivers
Re: Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
Prev: RE: Building Epics base 3.15.2 in Windows 7 Mark Rivers
Next: RE: Building Epics base 3.15.2 in Windows 7 Mark S. Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Building Epics base 3.15.2 in Windows 7 Andrew Johnson
