1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: menu choice - scalcout?
To: Rob Emery <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 17 Nov 2015 05:36:01 +0000
You could do this is with an mbbo record followed by an scalcout record.  If the text strings are all shorter than 16 bytes, the mbbo record could hold the text strings in a form that EDM and other display managers already know how to display as a menu.  The mbbo record's forward link would process the scalcout record.  The scalcout record's INPA link would read from the mbbo record's RVAL field.  The scalcout record's INAA, INBB, INCC, etc. links would read from the mbbo record's ZRST, ONST, TWST, etc. fields, respectively.  The scalcout record's calc _expression_ would be "@@A"; this _expression_ tells the scalcout record to use the AA field if A==0, the BB field if A==1, the CC field if A==2, etc.
If the text strings are longer than 15 bytes but shorter than 40 bytes, you could do something similar.  The mbbo record string fields would not contain exactly the strings to be sent, but only abbreviated versions for the user to choose from.  The actual strings to be sent would be hard coded in the scalcout record's STRn fields, instead of being read from the mbbo record's string fields.
If there are more than 16 strings, you could use an mbbo/scalcout pair for each set of 16 strings, and they would have to be on separate menu buttons in the EDM display.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Rob Emery [[email protected]]
Sent: Monday, November 16, 2015 8:22 PM
To: [email protected]
Subject: menu choice - scalcout?
I would like to be able to use a radio box or menu button in EDM to send one of a pre-defined set of text strings to a record.  How would I do this?  Somehow modify scalcout to include a menu of choices?
Thanks
Rob Emery
UW Medical Center
menu choice - scalcout? Rob Emery
Prev: menu choice - scalcout? Rob Emery
Next: synApps modules will move to GitHub: optics, softGlue, sscan, stream, support Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
