1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’
To: <[email protected]>
Date: Tue, 24 Nov 2015 09:52:25 -0600
Henrique:
thanks for your suggestion.
We will look at what compels the next release of synApps. IMO, this change, by itself, is not sufficient to justify the work to make a new release.
Until we make a new synApps release, you can install new releases of any module(s) alongside the existing modules in the support directory. Such as:
support/
   caputRecorder
   caputRecorder_1-5-1
Then, update the configure/RELEASE file with the new module path(s), then do a rebuild in the support directory:
make release
make
This leaves you in a position to revert to a pristine synApps 5.8 configuration, should you so require.
Pete
On 11/24/2015 8:58 AM, Henrique Almeida wrote:
  Mark, I can confirm that replacing the caputRecorder in synApps 5.8
with the github master branch solved the problem. However, my plan was
using an unmodified synApps version. You said that the latest version of
each module works with the latest version of all other modules. But
synApps itself is not working with the latest EPICS base version. Since
EPICS base 3.15.2 was released in May, then this rule has been broken
for synApps for the last 6 months. Maybe it's time to release synApps 5.9 ?
2015-11-23 18:15 GMT-02:00 Mark Rivers <[email protected]
<mailto:[email protected]>>:
    You can now find the latest versions of all the synApps modules in
    https://github.com/epics-modules.
    There have been 3 releases of caputRecorder since synApps 5.8.
    Generally the latest tagged version of each module will work with
    the latest tagged version of all other modules.
    I am using the latest version of all synApps modules now with no
    problems.
    -----Original Message-----
    [mailto:[email protected]
    <mailto:[email protected]>] On Behalf Of Henrique Dante
    de Almeida
    Sent: Monday, November 23, 2015 2:02 PM
    To: [email protected] <mailto:[email protected]> Talk
    Subject: error: ‘dbChannel’ has no member named ‘final_dbr_type’
      Hello, I'm building synApps 5.8 on a fresh Red Hat 6.6 install and
    I'm receiving the following error:
    /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_
    -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32
    -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I..
    -I../../../include/compiler/gcc -I../../../include/os/Linux
    -I../../../include
    -I/usr/local/epics/base-3.15.2/include/compiler/gcc
    -I/usr/local/epics/base-3.15.2/include/os/Linux
    -I/usr/local/epics/base-3.15.2/include        -c ../caputRecorder.c
    ../caputRecorder.c: In function ‘myAsDataListener’:
    ../caputRecorder.c:283: error: ‘dbChannel’ has no member named
    ‘final_dbr_type’
    (etc.)
      It seems that there exists a patch for this problem:
    https://subversion.xor.aps.anl.gov/trac/synApps/changeset/19339
      Are there plans for merging this patch in synApps ? What about a
    new synApps release ?
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Dante de Almeida
RE: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Mark Rivers
Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Almeida
Prev: Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Almeida
Next: RE: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
