1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’
To: "Mooney, Tim M." <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Tue, 24 Nov 2015 13:59:08 -0500
Tim,
... the entire effort to identify and assemble collections of software that work together.
I for one would like to thank you for the non-trivial effort that goes into this.  It would be technically straightforward to produce a new synapps "release" every day based on the latest release versions of the component module, or even from VCS (for the truly brave).  However doing so would lose much of the value that synapps provides to non-experts.
Of course I know well the effort involved since I did it myself three times while at BNL to assemble the synapps debian package, which diverged following synapps 5.5.
synApps is intended to be upgraded in place between releases, and contains software (makeReleaseConsistent.pl, release.pl)
The complaint I would have about this approach is that it encourages everyone to have a different combination of versions, which then separate needs validation.  For efficiency (which I assume motivates us all) it would be good to minimize the number of different combinations of versions.
This is compounded by that fact that no one else know which combinations have been tested by say, Mark, and which are truly new.
Of course I don't have a magic solution for this.  I suppose one place to start is documenting which collections of versions are being used/tested at different facilities.  For example, the current state and history of the debian synapps package is here:
https://github.com/epicsdeb/synapps/blob/master/debian/changelog
Michael
On 11/24/2015 01:00 PM, Mooney, Tim M. wrote:
synApps is intended to be upgraded in place between releases, and contains software (makeReleaseConsistent.pl, release.pl) to support that practice, because that has been a convenient way for us to stay current with all the disparate development efforts (base, seq, asyn, motor, autosave, etc.) on which  synApps modules depend.  The fact that a synApps release is not compatible with a version of base released two month later doesn't in my mind invalidate the entire effort to identify and assemble collections of software that work together.
When only one or a few module-version changes are needed to produce a working collection, I think it's not time for a new synApps release, because the upgrade-in-place strategy handles that well.  But when a module on which many other synApps modules depends changes, then upgrade-in-place becomes impractical, and a new synApps release is needed.
This strategy has worked pretty well, I think.  In my 20+ years of running synApps on our beamlines and labs, I have always been able to run an official synApps release, and I have also been able to make module-version changes needed by one beamline without exposing other beamlines to any risk.  In this way, the new module version gets tested at only the beamline that expects to benefit from it.  Once vetted, that module version presents less risk for inclusion in the next version of synApps.
This vetting of individual modules in older releases of synApps is important, because it's more efficient and thorough to test  software with the hardware on which it's intended to run, and we don't own that hardware.  We have no beamline at our disposal for testing.  The only way we can test with hardware is to persuade a beamline to upgrade, and we persuade them by exposing them only to the new software they've told us they want.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Tuesday, November 24, 2015 10:08 AM
To: 'Henrique Almeida'
Cc: [email protected] Talk
Subject: RE: error: ‘dbChannel’ has no member named ‘final_dbr_type’
Hi Henrique,
Personally I don’t find the concept of synApps releases very useful.  Every official synApps release has significant bugs and build problems, and is almost instantly out of date because it lacks major new features of one or more support modules.  In my 20+ years of running synApps on our beamlines and labs I have never been able to run an official synApps release.
For example, in the 11 months since synApps 5-8 was released the following synApps modules have had a total of 27 new tagged releases:
alive: 1-0-1
areaDetector/ADCore: 2-2, 2-3, 2-4
asyn: 4-26, 4-27
autosave: 5-6-2, 5-7, 5-7-1
calc: 3-5, 3-6, 3-6-1
caputRecorder: 1-4-3, 1-5, 1-5-1
dxp: 3-5
iocStats: 3.1.14
ip: 2-10
optics: 2-10, 2-11
softGlue: 2-5, 2-6, 2-7
sscan: 2-10-2
stream: 2-6b, 2-6c
xxx: 5-8-4
Each of these releases either fixes significant bugs, adds significant new features, or both.  At what point should a new synApps release be made?  It will clearly be obsolete in less than 2 weeks on average, since there are 27 releases of synApps modules in less than 1 year.
I would find it much more helpful if rather than official synApps releases there were simply a list of known incompatibilities of the latest release of module X with the latest tagged release of module Y.
Sent: Tuesday, November 24, 2015 8:59 AM
To: Mark Rivers
Cc: Henrique Dante de Almeida; [email protected] Talk
 Mark, I can confirm that replacing the caputRecorder in synApps 5.8 with the github master branch solved the problem. However, my plan was using an unmodified synApps version. You said that the latest version of each module works with the latest version of all other modules. But synApps itself is not working with the latest EPICS base version. Since EPICS base 3.15.2 was released in May, then this rule has been broken for synApps for the last 6 months. Maybe it's time to release synApps 5.9 ?
2015-11-23 18:15 GMT-02:00 Mark Rivers <[email protected]>:
You can now find the latest versions of all the synApps modules in https://github.com/epics-modules.
There have been 3 releases of caputRecorder since synApps 5.8.
Generally the latest tagged version of each module will work with the latest tagged version of all other modules.
I am using the latest version of all synApps modules now with no problems.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Henrique Dante de Almeida
Sent: Monday, November 23, 2015 2:02 PM
To: [email protected] Talk
Subject: error: ‘dbChannel’ has no member named ‘final_dbr_type’
 Hello, I'm building synApps 5.8 on a fresh Red Hat 6.6 install and I'm receiving the following error:
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/local/epics/base-3.15.2/include/compiler/gcc -I/usr/local/epics/base-3.15.2/include/os/Linux -I/usr/local/epics/base-3.15.2/include        -c ../caputRecorder.c
../caputRecorder.c: In function ‘myAsDataListener’:
../caputRecorder.c:283: error: ‘dbChannel’ has no member named ‘final_dbr_type’
(etc.)
 It seems that there exists a patch for this problem:
https://subversion.xor.aps.anl.gov/trac/synApps/changeset/19339
 Are there plans for merging this patch in synApps ? What about a new synApps release ?
error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Dante de Almeida
RE: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Mark Rivers
Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Almeida
RE: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Mooney, Tim M.
Prev: Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Almeida
Next: Re: caPutLog problem solved Qiao Yusi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Missaligned protocol rejected when using caPutLog Qiao Yusi
