1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem building msi with base-3.15.3
To: <[email protected]>
Date: Wed, 2 Dec 2015 14:03:40 -0600
Hi Pete,
Base-3.15 compiles its own version of msi which has some additional
features. Please switch to using that instead of the copy from the
extensions tree, which cannot be used with the 3.15 build rules anyway
(which require support for a -D flag to have it output dependency data).
I have deliberately not published a version of msi that builds against
base-3.15.
- Andrew
On 12/02/2015 01:56 PM, Jemian, Pete R. wrote:
> ran into this problem when building msi with base-3.15.3
> -----------------------------% clip here %-----------------------------
> prjemian@poka /usr/local/epics/extensions/src $ make
> make -C ./msi install
> make[1]: Entering directory `/usr/local/epics/extensions/src/msi'
> perl -CSD /usr/local/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
> mkdir O.Common
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
> 	    T_A=linux-x86_64 install
> make[2]: Entering directory `/usr/local/epics/extensions/src/msi/O.linux-x86_64'
> ../../../configure/RULES_PYTHON:44: *** target file `clean' has both : and :: entries.  Stop.
> make[2]: Leaving directory `/usr/local/epics/extensions/src/msi/O.linux-x86_64'
> make[1]: *** [install.linux-x86_64] Error 2
> make[1]: Leaving directory `/usr/local/epics/extensions/src/msi'
> make: *** [msi.install] Error 2
> Fixed it for me by removing the second colon from that line.
> Is that the _correct_ fix?
> Here's the versions of my EPICS components in my build:
> -rw-r--r--  1 prjemian prjemian   1603523 Dec  2 10:54 base-3.15.3.tar.gz
> -rw-r--r--  1 prjemian prjemian      6476 Dec  2 13:45 extensionsConfigure_20070703.tar.gz
> -rw-r--r--  1 prjemian prjemian     12409 Dec  2 13:45 extensionsTop_20120904.tar.gz
> -rw-r--r--  1 prjemian prjemian     12015 Dec  2 13:48 msi1-7.tar.gz
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: problem building msi with base-3.15.3 Pete Jemian
problem building msi with base-3.15.3 Jemian, Pete R.
Prev: problem building msi with base-3.15.3 Jemian, Pete R.
Next: Re: problem building msi with base-3.15.3 Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
