1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem building msi with base-3.15.3
Date: Wed, 2 Dec 2015 19:56:02 +0000
ran into this problem when building msi with base-3.15.3
-----------------------------% clip here %-----------------------------
prjemian@poka /usr/local/epics/extensions/src $ make
make -C ./msi install
make[1]: Entering directory `/usr/local/epics/extensions/src/msi'
perl -CSD /usr/local/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
	    T_A=linux-x86_64 install
make[2]: Entering directory `/usr/local/epics/extensions/src/msi/O.linux-x86_64'
../../../configure/RULES_PYTHON:44: *** target file `clean' has both : and :: entries.  Stop.
make[2]: Leaving directory `/usr/local/epics/extensions/src/msi/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/usr/local/epics/extensions/src/msi'
make: *** [msi.install] Error 2
Fixed it for me by removing the second colon from that line.
Is that the _correct_ fix?
Here's the versions of my EPICS components in my build:
-rw-r--r--  1 prjemian prjemian   1603523 Dec  2 10:54 base-3.15.3.tar.gz
-rw-r--r--  1 prjemian prjemian      6476 Dec  2 13:45 extensionsConfigure_20070703.tar.gz
-rw-r--r--  1 prjemian prjemian     12409 Dec  2 13:45 extensionsTop_20120904.tar.gz
-rw-r--r--  1 prjemian prjemian     12015 Dec  2 13:48 msi1-7.tar.gz
Re: problem building msi with base-3.15.3 Andrew Johnson
Prev: RE: Streamdevice initialization sequence Mark Rivers
Next: Re: problem building msi with base-3.15.3 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
