1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Streamdevice initialization sequence
To: "'Christian Pauly'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 2 Dec 2015 19:02:22 +0000
One solution would be to add the following commands to your startup script before iocInit:
asynOctetConnect("myDevice", "myPort", 0)
asynOctetWrite("myDevice", "*RST")
where "myPort" is the name of the asynIP or asynSerial port, and "myDevice" is an arbitrary name you chose.
That way you will reset the device before the @init sections are run, which happens as part of iocInit.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Christian Pauly
Sent: Wednesday, December 02, 2015 12:52 PM
To: EPICS Tech Talk
Subject: Streamdevice initialization sequence
Hi
I have a question regarding Streamdevice and the initialization of the
hardware on ioc startup.
I would liko to control an Agilent 33250A Pulse generator using stream
device.
In order to put the device in a well defined ground state on startup of
the IOC, i would like to send a RESET command ("*RST") first.
Afterwards i would like to put the device in a well-defined initial
configuration (which might be different then the reset state) by using
the @init directive in different protocol functions (as described in the
streamdevice docu).
The best would be, to have a separate protocoll function with @init
section, which is only used for initial reset+configuration, and which
is for sure processed before all others.
However, after some trying and reading the manual, i understand that the
individual @init sections from different protocol functions are
processed in a more or less random, non-defined order.
How can i make sure, that a "*RST" command is executed first, before
later the individual protocol routines @init sections are used to read
the device status into the control records
(here i dont care any more about the sequence)?
I dont want to shift all initialization into the db record definition
using a initialization record ("PINI 1"), since then the individual
@init sections, used to fill the records with the actual device status
at startup, would be processed before the *RST command, and the records
would not reflect the real device status at startup.
Is there any standard concept for this problem ?
Thanks for any advice,
Christian
Streamdevice initialization sequence Christian Pauly
Prev: Streamdevice initialization sequence Christian Pauly
Next: problem building msi with base-3.15.3 Jemian, Pete R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
