1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Streamdevice initialization sequence
To: EPICS Tech Talk <[email protected]>
Date: Wed, 02 Dec 2015 19:52:27 +0100
Hi
I have a question regarding Streamdevice and the initialization of the hardware on ioc startup. I would liko to control an Agilent 33250A Pulse generator using stream device. In order to put the device in a well defined ground state on startup of the IOC, i would like to send a RESET command ("*RST") first. Afterwards i would like to put the device in a well-defined initial configuration (which might be different then the reset state) by using the @init directive in different protocol functions (as described in the streamdevice docu).
The best would be, to have a separate protocoll function with @init section, which is only used for initial reset+configuration, and which is for sure processed before all others.
However, after some trying and reading the manual, i understand that the individual @init sections from different protocol functions are processed in a more or less random, non-defined order.
How can i make sure, that a "*RST" command is executed first, before later the individual protocol routines @init sections are used to read the device status into the control records
(here i dont care any more about the sequence)?
I dont want to shift all initialization into the db record definition using a initialization record ("PINI 1"), since then the individual @init sections, used to fill the records with the actual device status at startup, would be processed before the *RST command, and the records would not reflect the real device status at startup.
Is there any standard concept for this problem ?
Thanks for any advice,
Christian
RE: Streamdevice initialization sequence Mark Rivers
Prev: Re: migration from old EPICS Base Andrew Johnson
Next: RE: Streamdevice initialization sequence Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: migration from old EPICS Base Hartman, Steven M.
