1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: migration from old EPICS Base
To: EPICS tech-talk <[email protected]>, Jiro Fujita <[email protected]>
Date: Thu, 3 Dec 2015 00:25:04 +0000
Hello Jiro
When I was at the Duke FEL, I updated IOCs from base 3.12 (or was it 3.11?) and one even from base 3.9!
I wrote device support for the VMIVME 3122 and 4116, and for VMIVME digital input and digital output boards (not the same as yours but similar). The code compiled and ran on both 3.13 and 3.14 IOCs, but was VxWorks specific. It should not be very difficult to update them to use the OSI layer to be able to run under RTEMS.
The Duke website that hosted the code is no longer available, but I'll see if I can find it for you.
Steven Hartman
Date: December 2, 2015 at 11:28:17 EST
Subject: migration from old EPICS Base
So, here is a question to people who has been in the control business for a while.
At STAR experiment at Brookhaven National Lab, we still have some IOCs running EPICS Base 3.12 (as well as 3.13 and 3.14).  Since prior to EPICS 3.14, we could only use EPICS with VME boards, they are running on VME CPUs.  All of them are basically frozen systems.  We do boot them from a Linux host, but we have not made any changes to them for several years.
As we try to deal with the aging older hardware, I have found that we are still using the following VME boards in those old EPICS Base 3.12 based IOCs:
VMIVME 1111     64-bit High-Voltage Digital Input Board
VMIVME 2232     32-Channel Relay Output Board
VMIVME 3122     16-bit Analog-To-Digital Converter Board
VMIVME 4116     8-Channel 16-bit Analog Output Board
LeCroy 1176 TDC Time-to-Digital Converter Board
Acromag AVME 948X Digital I/O card
I realize many of VMIVME boards are listed in EPICS Hardware Support section, but many of them has no contact person listed (nor the code), not clear if it is supported in EPICS Base 3.14.
Does anybody by any chance still use them with EPICS Base 3.14 or even 3.15?  If you do, please let me know.  Note that if we are to move VME IOCs to EPICS Base 3.14, it is very likely that we will use RTEMS instead of VxWorks (mostly cost issues).  So any experiences of migrating from VxWorks to RTEMS is also welcome.
If anybody have replaced them to something newer that are better supported in EPICS Base 3.14/3.15, I am also interested to hear what you replaced them with.
My thought is that anything that's currently running with EPICS Base 3.12 stable, we should leave them alone in general, given the lack of man power and budget to move them to newer systems.  However, my boss thinks otherwise, so I was given a task of looking into the possibilities and options.
migration from old EPICS Base Jiro Fujita
Prev: Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Andrew Johnson
Next: ai RVAL via asyn + modbus: getting unsigned integer jon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: migration from old EPICS Base Wesley Moore
Next: Streamdevice initialization sequence Christian Pauly
