1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem
To: <[email protected]>
Date: Wed, 2 Dec 2015 16:28:12 -0600
Hi Mike,
On 12/02/2015 08:51 AM, Michael Westfall wrote:
> Oops. Having a problem compiling Base for RTEMS 4.10 / beatnik BSP:
> /gemsoft/opt/rtems/4.10/lib/gcc/powerpc-rtems4.10/4.4.7/../../../../powerpc-rtems4.10/bin/ld:
> cannot find -lbspExt
> collect2: ld returned 1 exit status
> make[3]: *** [rtemsTestHarness] Error 1
> make[3]: Leaving directory
> `/gemsoft/opt/epics/base-3.14.12.5/src/libCom/test/O.RTEMS-beatnik'
> What did I forget to do?
libbspExt is an RTEMS module from SLAC which you need to download and
build separately, see
  http://www.slac.stanford.edu/~strauman/rtems/software.html
This is the last module built in my instructions given at
  http://www.aps.anl.gov/epics/base/RTEMS/Building-4.10.2.txt
HTH,
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Michael Westfall
Prev: Re: EPICS Base 3.15.3 released Andrew Johnson
Next: Re: migration from old EPICS Base Hartman, Steven M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Michael Westfall
Next: Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Michael Westfall
