1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine
To: <[email protected]>
Date: Wed, 9 Dec 2015 10:00:07 -0500
OFFICIAL USE ONLY / À USAGE EXCLUSIF
Hello,
I will start will giving some of the environment details:
Host Machine:
Ubuntu 12.04 (3.13.0-71-generic kernel) x86_64
I am building IOC’s for 64 and 32-bit machines; I am also cross compiling for ARM (Raspberry Pi), with crosstools-ng.
The build is successful for 64 bit binaries and the 32-bit cross compile, but I keep getting an error for x86:
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/libstdc++.so when searching for -lstdc++
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/libstdc++.a when searching for -lstdc++
/usr/bin/ld: cannot find -lstdc++
collect2: ld returned 1 exit status
make[3]: *** [libCom.so.3.14] Error 1
make[3]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src'
make: *** [src.install] Error 2
I have the gcc-multilib package, and lib32, and I followed this advice:
base/configure/os/CONFIG_SITE.linux-x86.Common:
# T.S, 2006/09/05
# add -m32 so we create 32-bit code when
# executing on 64-bit machine with EPICS_HOST_ARCH=linux-x86
ARCH_DEP_CFLAGS+=-m32
ARCH_DEP_CXXFLAGS+=-m32
ARCH_DEP_LDFLAGS+=-m32
Thanks you in advance for your help,
Lee
RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Mark Rivers
Re: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Michael Davidsaver
Re: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Andrew Johnson
Prev: Re: Proposed change to asyn drvAsynIPPort for UDP sockets Eric Norum
Next: RE: Proposed change to asyn drvAsynIPPort for UDP sockets Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Request for information from institutions with Archiver Appliance deployments Konrad, Martin
Next: RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Mark Rivers
