1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine
To: "'Cusick, Martin-Lee'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 9 Dec 2015 17:23:33 +0000
Are you sure you have installed both the 64-bit and 32-bit versions of the system library libstdc++.so?
Here are the files on my Fedora system:
7233436    0 lrwxrwxrwx   1 root     root           37 Apr 10  2012 /usr/lib/gcc/x86_64-redhat-linux/4.6.3/libstdc++.so -> ../../../../lib64/libstdc++.so.6.0.16
7233434    0 lrwxrwxrwx   1 root     root           31 Apr 10  2012 /usr/lib/gcc/x86_64-redhat-linux/4.6.3/32/libstdc++.so -> ../../../../libstdc++.so.6.0.16
Note that there are both 64-bit and 32-bit versions of that library.
Do you find both 64-bit and 32-bit versions of libstdc++.so on your system?
From: [email protected] [mailto:[email protected]] On Behalf Of Cusick, Martin-Lee
Sent: Wednesday, December 09, 2015 9:00 AM
To: [email protected]
Subject: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine
OFFICIAL USE ONLY / À USAGE EXCLUSIF
Hello,
I will start will giving some of the environment details:
Host Machine:
Ubuntu 12.04 (3.13.0-71-generic kernel) x86_64
I am building IOC’s for 64 and 32-bit machines; I am also cross compiling for ARM (Raspberry Pi), with crosstools-ng.
The build is successful for 64 bit binaries and the 32-bit cross compile, but I keep getting an error for x86:
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/libstdc++.so when searching for -lstdc++
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/libstdc++.a when searching for -lstdc++
/usr/bin/ld: cannot find -lstdc++
collect2: ld returned 1 exit status
make[3]: *** [libCom.so.3.14] Error 1
make[3]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src'
make: *** [src.install] Error 2
I have the gcc-multilib package, and lib32, and I followed this advice:
base/configure/os/CONFIG_SITE.linux-x86.Common:
# T.S, 2006/09/05
# add -m32 so we create 32-bit code when
# executing on 64-bit machine with EPICS_HOST_ARCH=linux-x86
ARCH_DEP_CFLAGS+=-m32
ARCH_DEP_CXXFLAGS+=-m32
ARCH_DEP_LDFLAGS+=-m32
Thanks you in advance for your help,
Lee
RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
Prev: RE: Proposed change to asyn drvAsynIPPort for UDP sockets Mark Rivers
Next: RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
