* Set all the records you want to process when the alarm occurs to *.SCAN=Event; EVNT=<reserved_event_1>
* Use a calcout record to monitor the records you want to respond to and the conditions on which to take action ...
<importantPV1.SEVR>
<importantPV2.SEVR>
* set the "Out Event" field of the calcout record (OEVT) to <reserved_event_1>
Numerous records will scan when your conditions are met.
Ned
Hello, what's the proper way to process a record if and only if another record raises an alarm ?
- Alarm handling Henrique Almeida
Re: Alarm handling Kasemir, Kay
Re: Alarm handling Andrew Johnson
<2015>
2025
2026
<2015>
2025
2026
ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
