1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MEDM Extension Make Failed on Ubuntu 15.10
To: <[email protected]>
Date: Mon, 14 Dec 2015 18:34:46 +0100
Hello Guys,
I am new to EPICS. I am using EPICS base-3.15.3. I am using Ubuntu 15.10 64bit as test OS (I also need to install it on Debian 8.1 later on, which is my server). Following is my epics installation directory structure
~/epics/base (successfully build)
~/epics/extensions
I am trying to install medm3.1.9 extension. After running "adeel@ubuntu1510:~/epics/extensions/src/medm$ make" , I am getting following errors (after some compiling)
../xgif.c:156:9: warning: variable ‘x’ set but not used [-Wunused-but-set-variable]
     int x, y;
make[2]: *** No rule to make target '/usr/lib64/libXm.a', needed by 'medm'. Stop. make[2]: Leaving directory '/home/adeel/epics/extensions/src/medm/medm/O.linux-x86_64' ../../../../base/configure/RULES_ARCHS:64: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/adeel/epics/extensions/src/medm/medm'
../../../base/configure/RULES_DIRS:87: recipe for target 'medm.install' failed
make: *** [medm.install] Error 2
It seems the problem is with libXm.a which is part of libxp-dev and its not available on Ubuntu 15.10. I downloaded libxp-dev from launchpad but it need libxp6 which is also not available on ubuntu. I searched on tech-talk but I couldn't find the satisfactory solution. I will appreciate your expert help. Please link if solution is already given (may be I could not get it).
Best,
Adeel Akram
Universität Heidelberg.
RE: MEDM Extension Make Failed on Ubuntu 15.10 Mark Rivers
Re: MEDM Extension Make Failed on Ubuntu 15.10 Andrew Johnson
Re: MEDM Extension Make Failed on Ubuntu 15.10 Jeong Han Lee
Prev: Control System Engineer position at TRIUMF Rod Nussbaumer
Next: Newbie: How do I view the output of an areaDetector plugin? Phil Atkin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: MEDM Extension Make Failed on Ubuntu 15.10 Mark Rivers
