1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: areaDetector plugins: what variables can be accessed while unlocked?
To: <[email protected]>
Date: Tue, 15 Dec 2015 10:51:45 +0000
In the "Guidelines and rules for plugins" is this statement: "Obviously [plugins] must not access memory locations that other threads could modify [while the mutex lock is not taken], so they should only access local variables, not class variables (which includes the parameter library)".
I think it should be OK to access member variables of the plugin class (i.e. the class derived from NDPluginDriver), in addition to local (stack) variables.  And I presume that by "class variables" what's meant is members that are generally referred to in C++ as static member variables.  Am I correct?
Cheers,
Phil
Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
RE: areaDetector plugins: what variables can be accessed while unlocked? Mark Rivers
Prev: RE: ai RVAL via asyn + modbus: getting unsigned integer jon
Next: RE: areaDetector plugins: what variables can be accessed while unlocked? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: areaDetector: plugin in separate dll Mark Rivers
