1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ai RVAL via asyn + modbus: getting unsigned integer
Date: Mon, 14 Dec 2015 14:45:02 -0800
Mark, that did fix the problem - changing nbits in INP asynMask from 16 (for unipolar) to -16 (for bipolar). Thanks so much!  -- Jon
PS - so now small negative input voltages result in small negative integer RVAL,
with Vin -0.005 V:
epics> dbgf Iso:GantryCouch:Collimator:Actual.RVAL
DBR_LONG:           -8        0xfffffff8
On Mon, 14 Dec 2015, Mark Rivers wrote:
I believe I may have found your problem.
 field(DTYP, "asynInt32")
 field(INP, "@asynMask(CollimCouch, $(OFFSET), 16, 1000)MODBUS_DATA")
So you are using asynInt32 device support with the asynMask link syntax.
This is the documentation from for asynInt32 and asynMask from http://cars9.uchicago.edu/software/epics/modbusDoc.html ...
field(INP,"@asynMask(portName,offset,nbits,timeout)drvUser")
nbits>0 for a unipolar device. For example, nbits=12 means unipolar 12-bit device, with a range of 0 to 4095. nbits<0 for a bipolar device. For example, nbits=-12 means bipolar 12-bit device, with a range of -2048 to 2047)
So you have set nbits=16.  But the documentation explains the nbits>0 is for unipolar devices.  Yours is not a unipolar device, it is a bipolar device, so you should be setting nbits=-16.
I believe that will fix your problem.
RE: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
Prev: Re: MEDM Extension Make Failed on Ubuntu 15.10 Jeong Han Lee
Next: areaDetector plugins: what variables can be accessed while unlocked? Phil Atkin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
Next: EPICS 2016 Spring Meeting at ESS, Lund, Sweden Timo Korhonen
