1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics docker container
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 16 Dec 2015 10:41:36 +0100
Hi Carlos,
Thanks a lot for the pointers!
Some comments on your statements...
On 16/12/2015 09:32, Carlos Pascual wrote:
Finally, I must say that, as a complete alien to the EPICS world it took
me quite a lot of effort learning enough to set up such a minimal and
simple epics system (the "tutorial-style" docs I found were very lab-
specific and assumed a running system in place). This stresses the
convenience of a pre-packaged VM or docker image. I documented my own
"minimal-epics" installation in this short doc:
http://sf.net/p/tauruslib/wiki/howto-taurus-epics/
I know that the EPICS learning curve is not to be underestimated. And I agree that VM/Docker is a good way to provide an easy start.
However, for the records:
EPICS Base contains fairly complete example applications in the form of templates that you can instantiate and build. The "Application Developer's Guide" (which is the central document for EPICS) has a "Getting Started" chapter that walks you through the examples on a few pages.
The examples are completely self-contained and free of lab-specifics.
They do require an installation of EPICS Base, which (on modern standard systems) can be created by unpacking the distribution tar and running "make".
One more remark  about
> $ taurusform epics://XXX:random epics://XXX:a epics://XXX:b epics://XXX:sum
The EPICS V3 network protocol is called Channel Access. In URI-type notation, applications should use "ca:" to denote the scheme. The EPICS V4 (next generation) network protocol is called PV Access. Its common URI scheme tag is "pva:". Unless the "epics:" tag stands for something taurus-internal that is a different scheme and not Channel Access, I would really prefer a consistent naming.
Cheers,
~Ralph
epics:// vs. ca:// Re: epics docker container Kasemir, Kay
epics docker container Carlos Pascual
Prev: epics docker container Carlos Pascual
Next: Re: epics docker container Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: epics:// vs. ca:// Re: epics docker container Kasemir, Kay
