1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Pro's/Con's of LabVIEW/EPICS
To: "Wyman, Max D" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 21 Dec 2015 23:21:53 +0000
Hello Max
We (ELI Beamlines, Prague) are using the hybrid architecture for laser beamlines control. Recently, we published a paper which presents this and other details of our laser controls:
http://icalepcs.synchrotron.org.au/papers/tud3o02.pdf
http://icalepcs.synchrotron.org.au/talks/tud3o02_talk.pdf
One of the advantages of having hybrid LabVIEW/EPICS is reliable and scalable integration done by Channel Access protocol. In our case, CA integrates EPICS IOCs, LabVIEW controllers, instruments and also turn-key laser systems and so CA implements overall supervisory layer.
I think, that is exactly what is missing in LabVIEW world -- scalable SCADA-like protocol. or system. One can go with third-party or with open-source like EPICS/CA.
We aim for 100s to few 1000s of PVs per laser beamline (so times 4 in total) while keeping 10Hz rate as limit for top-level supervisory data exchange.
After an experience with LabVIEW I/O server (DCS) and after researched other options with our HW options/decisions on mind, we rather provisioned LabVIEW SW implementation of CA-server/-client from Observatory Sciences Ltd.
So now, on both sides (EPICS and LabVIEW), events passing can utilize camonitor routines and error handling can be managed with particular Process Variable fields -- standard to EPICS records. Then ca_get and puts are there and about ten of standard PV (record) types  are supported.
Tomas
Od: [email protected] [[email protected]] za uživatele Wyman, Max D [[email protected]]
Odesláno: 17. prosince 2015 20:50
Komu: [email protected]
Předmět: Pro's/Con's of LabVIEW/EPICS
Hello,
I’m investigating the pro’s/con’s of a hybrid LabVIEW/EPICS system for the control and DAQ on PRIME Lab’s accelerator. We’ll be adding a second ion source (and requisite controllers) so it seems like a good time to make such a migration if it seems beneficial.  Currently we use a suite of LabVIEW applications for control/DAQ of a dozen NI cRIOs, a handful of NI GPIB-ethernet controllers, and two NI PXI chassis as our input/output controllers.
In particular, I’m curious to talk to anybody who’s ever migrated a system from pure LabVIEW to a LabVIEW/EPICS hybrid or who currently runs an EPICS system involving controllers similar to ours (the NI cRIOs, PXI crates, and GPIB-ENET controllers).
Max
Max Wyman
PRIME Lab, Purdue University
765-496-6894
Pro's/Con's of LabVIEW/EPICS Wyman, Max D
Prev: Re: Pro's/Con's of LabVIEW/EPICS Southern, Tim
Next: EPICS synApps installation ERROR. Please, Help me. [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Is there any demo or doc of the VTable Display in CCS? WangWill
ANJ, 22 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
