1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS BOY and Raspberry Pi?
To: Ryan Pierce <[email protected]>
Date: Wed, 23 Dec 2015 08:50:37 -0800
PID doesn’t work will with plants that have long transport delays or dead times.  A more appropriate technique is something like the Smith Predictor: http://www.mathworks.com/help/control/examples/control-of-processes-with-long-dead-time-the-smith-predictor.html?s_tid=gn_loc_drop
On Dec 22, 2015, at 9:12 PM, Ryan Pierce <[email protected]> wrote:
I'm guessing the initial overshoot happened due to a number of reasons. (Residual heat in the stainless steel base of the keg needing time to transfer to the water? With 10+ gallons of water in the keg, convection to equalize temperature may not be efficient? Lag time in the thermal probe?) I'd think an ideal control algorithm should anticipate that with a large commanded temperature change, cutting off the burner early is necessary to prevent an overshoot, but that would be unnecessary with just a small 0.5 degree F change. I'm guessing this is a common control systems problem, so rather than reinvent the wheel, is there a standard algorithm that handles this? Or can PID be used in a situation like this?
Eric Norum
[email protected]
CSS BOY and Raspberry Pi? Ryan Pierce
Prev: Re: CSS BOY and Raspberry Pi? Pearson, Matthew R.
Next: Re: EPICS synApps installation ERROR. Please, Help me. Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Problem: nozzle exchanger Local/Remote pv value is not received 박무진
ANJ, 24 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
