1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem: nozzle exchanger Local/Remote pv value is not received
To: [email protected]
Date: Thu, 24 Dec 2015 14:14:27 +0900 (KST)
Hello..
i'm reparing the ioc of Nozzle Exchanger.
Now, pv value (Local/Remote) is viewing in medm... but this is decoy... i think it is default value.
when i switch Remote/Local S/W in Nozzle Exchanger, pv value in medm is not changed.
this pv value is a valuable data?
 i know "st.cmd" deamon is ioc deamon. so i stoped "st.cmd" deamon.
and i see all of pv value in medm is blanked. and i started "st.cmd" so, i see all of py value is displayed (but these value is not correct)
and i updated .db of device and i restart ioc deamon
i add the pv object in medm. and i see the  default value of added pv in medm
is this situation correct?
somthing is missed..
devNozzleExchange.db
record(bi, "$(P)$(D):GetRemoteSta")
    field(DESC, "Local/Remote Status")
    field(DTYP, "stream")
    field(INP,  "@devNozzleExchange.proto GetRemoteSta $(PORT) $(A)")
    field(ZNAM, "Local")
    field(ONAM, "Remote")
    field(SCAN, ".2 second")
    field(FLNK, "$(P)$(D):GetCryoSolSta")
devNozzleExchage.proto
@writetimeout { disconnect; }
@replytimeout { disconnect; }
@readtimeout  { disconnect; }
@mismatch     { disconnect; }
ReplyTimeout = 1200;
InTerminator = "\r\n";
OutTerminator = "\r\n";
# Measure current
GetRemoteSta {
    out "!50SWS";
    in "?50%1d";
    ExtraInput = Ignore;
GetCryoSolSta {
    out "!51SOL";
    in "?51%1d%*2d";
this is code...
블로그서명
블로그진스
Re: Problem: nozzle exchanger Local/Remote pv value is not received Mark Rivers
Prev: Re: EPICS synApps installation ERROR. Please, Help me. Mark Engbretson
Next: Re: Problem: nozzle exchanger Local/Remote pv value is not received Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS BOY and Raspberry Pi? Eric Norum
ANJ, 24 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
