You should enable asynTrace on the $(PORT) and $(A) to see what is actually happening with communication with the device.
asynSetTraceIOMask($(PORT), $(A), 2)
asynSetTraceMask($(PORT), $(A), 9)
Sent from my iPhone
On Dec 24, 2015, at 3:13 AM, 박무진 <[email protected]<mailto:[email protected]>> wrote:
Hello..
i'm reparing the ioc of Nozzle Exchanger.
Now, pv value (Local/Remote) is viewing in medm... but this is decoy... i think it is default value.
when i switch Remote/Local S/W in Nozzle Exchanger, pv value in medm is not changed.
this pv value is a valuable data?
i know "st.cmd" deamon is ioc deamon. so i stoped "st.cmd" deamon.
and i see all of pv value in medm is blanked. and i started "st.cmd" so, i see all of py value is displayed (but these value is not correct)
and i updated .db of device and i restart ioc deamon
i add the pv object in medm. and i see the default value of added pv in medm
is this situation correct?
somthing is missed..
devNozzleExchange.db
record(bi, "$(P)$(D):GetRemoteSta")
field(DESC, "Local/Remote Status")
field(DTYP, "stream")
field(INP, "@devNozzleExchange.proto GetRemoteSta $(PORT) $(A)")
field(ZNAM, "Local")
field(ONAM, "Remote")
field(SCAN, ".2 second")
field(FLNK, "$(P)$(D):GetCryoSolSta")
devNozzleExchage.proto
@writetimeout { disconnect; }
@replytimeout { disconnect; }
@readtimeout { disconnect; }
@mismatch { disconnect; }
ReplyTimeout = 1200;
InTerminator = "\r\n";
OutTerminator = "\r\n";
# Measure current
GetRemoteSta {
out "!50SWS";
in "?50%1d";
ExtraInput = Ignore;
GetCryoSolSta {
out "!51SOL";
in "?51%1d%*2d";
this is code...
블로그서명
[블로그]<http://blog.naver.com/pmjzzang78.do> 진스<http://blog.naver.com/pmjzzang78.do>
[http://mail.naver.com/readReceipt/notify/?img=bdRCDNG8WBgZhAn%2FFr%2B5FzJSM4K9MouXFzuZKrpCKqgwFzkvKxi4p6FCazEdpvIo%2BrkSKoU5W4d5W4C5bX0q%2BzkR74FTWx%2Fs%2Bzko1V9dM6wOtzJmbZlCW4m5prer.gif]
- Problem: nozzle exchanger Local/Remote pv value is not received 박무진
APS Shutdown and Network Maintenance Johnson, Andrew N.
<2015>
2025
2026
<2015>
2025
2026
