1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS synApps installation ERROR. Please, Help me.
To: Pete Jemian <[email protected]>
Cc: [email protected]
Date: Wed, 23 Dec 2015 14:41:33 -0600
Synapps is also NOT a single product. It is a grouping of different modules so any bin and lib files would be under the actual product directory, not in any sort of master bin, include, or lib files. This is because versions of everything change a lot, so would be harder to know exactly what you are building against if you had multiple versions.
On Dec 23, 2015, at 12:00, Pete Jemian <[email protected]> wrote:
The synApps has a different build structure than the EPICS extensions.
If synApps is installed in the extensions/src directory, it is not likely to be built at all.
The README file at the base of the synApps directory structure (https://github.com/EPICS-synApps/support/blob/master/README) has build instructions.
Which synApps version are you installing?
Did you get it from a .tar.gz file or from a source code repository?
Can you send the complete output from your gmake command?
Pete
> On 12/22/2015 8:06 PM, [email protected] wrote:
> hello.
> Pleas, Help me.
> I have some questions about EPICS installation.
> I use "fedora 20" with "Cinnamon desktop". User name is "cha"
> I installed the synApp in extensions directory and everything is fine
> (no any error come out from gmake).
> But when i check the file in extensions directory, The gmake did not
> build the "lib" directory.
> I am not sure why is happened, If you a a time and have some
> suggestions please would you let  me know???
> The extensions folder contains: bin, configure, html, Makefile,  README,
> and src
> But, no have "lib".
> I totally 10 time format and install again. again again.
> what's problems? please, help me
> Thanks.
> Cha
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
  Education is the one thing for which people
     are willing to pay yet not receive.
EPICS synApps installation ERROR. Please, Help me. [email protected]
Re: EPICS synApps installation ERROR. Please, Help me. Pete Jemian
Prev: Re: EPICS synApps installation ERROR. Please, Help me. Pete Jemian
Next: Problem: nozzle exchanger Local/Remote pv value is not received 박무진
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: CSS BOY and Raspberry Pi? Ryan Pierce
ANJ, 24 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
