1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: I have some question.. in .proto and .db files
To: mujin park <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 5 Jan 2016 19:01:30 +0000
Hi:
> i saw  field(SCAN, "I/O Intr") in record .. .
> what is mean?
The original meaning of "I/O Intr" was to scan the record on an _interrupt_ from the I/O device, for example some ADC card that can generate an interrupt.
Technically is just means that some EPICS device support modules can process the record when they decide that it's a good time to process the record, for example because the underlying hardware or network protocol provided a new value.
The stream device supports this as shown in the manual under http://epics.web.psi.ch/software/streamdevice/doc/processing.html#iointr . It typically requires one record to send a command to the device, and from then on the device will on its own send updates. As the stream device receives text from the device, it will then process records that are configured to with SCAN=I/O Intr.
-Kay
I have some question.. in .proto and .db files mujin park
Prev: Re: AreaDetector ADAndor - iXon Ultra 888 Dunning, Michael
Next: RE: AreaDetector ADAndor - iXon Ultra 888 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: I have some question.. in .proto and .db files Mark Rivers
Next: RE: I have some question.. in .proto and .db files peter.owens
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
