1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: terminal server/serial server/console management switch recommendations?
To: Mazanec Tomáš <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 11 Jan 2016 06:28:28 -0500
NSLS II also used Moxa devices to muster all serial interfaces. Contact Huijuan Xu at NSLS II. She is the design/implementation engineer for those devices.
On Mon, Jan 11, 2016 at 3:18 AM, Mazanec Tomáš <[email protected]> wrote:
Hi
We are happy with MOXA Nport so far.
NPort 5250A with 2 channels ; and NPort IA5450AI with 4 channels is more industrialized.
Both implement a lot of communication modes and features.
Tomas
Od: [email protected] [[email protected]] za uživatele Maren Purves [[email protected]]
Odesláno: 9. ledna 2016 2:29
Komu: EPICS tech-talk
Předmět: terminal server/serial server/console management switch        recommendations?
Hi all,
we have a number of serial line devices connected to a number
of IOCs (at 2 telescopes) examples are Lakeshore, Omega DP1s,
WXTs, Edwards gauges. Of old we are/were using Emulex terminal
servers but these things are getting up there in the years and
we lost a few already and had to replace them and we expect more
of them to go.
We have a few WTI CMS console management switches of an older
generation that we use to access computer consoles but I'm
not sure we currently have any measuring devices attached to
them. They work well with computers, including IOCs, once they
are set up to not use ^X as their disconnect character.
More recently we got some of these of a newer generation and we
have problems with them. One of the problems I have seen is that
even after configuring all ports to not have ^X as their disconnect
character they'll still send out ^Xs, and another problem that we
have a lot more frequently is that they don't drop the old connections
when one reboots an IOC. Currently the fastest way to reboot an IOC
is to halt it, manually disconnect all the serial ports and then
boot.
What are other people using, and would you recommend what you're
using or don't you?
Maren
RE: terminal server/serial server/console management switch recommendations? Richard Farnsworth
Re: terminal server/serial server/console management switch recommendations? Maren Purves
RE: terminal server/serial server/console management switch recommendations? Mazanec Tomáš
Prev: Re: MTCA4 HW management bob dalesio
Next: Error in installing the SynApp 5.7 mujin park
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: terminal server/serial server/console management switch recommendations? Mazanec Tomáš
Next: RE: terminal server/serial server/console management switch recommendations? Richard Farnsworth
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
