1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: RGA MKS Microvision 2
To: <[email protected]>, <[email protected]>
Date: Wed, 13 Jan 2016 16:16:46 +0000
Hello David and Keith,
If you have a link to the ASCII commands that would be useful and, David, It would be great if I could look at some code as well. When you say ASCII commands, I am thinking of a serial port but the MV2 only has an Ethernet port. Does the serial connect though that or do I need to set up something to connect to the digital I/O ports? I have attached a photo of its sockets to show you what I mean.
Thank you for your help.
Rory
Sent: 13 January 2016 15:34
To: Clarke, Rory (STFC,DL,TECH); [email protected]
Hi Rory,
The Microvision 2 RGA (MV2) understands a set of ASCII commands specified in the MKS documentation. Do you have the documentation and are you aware of the commands?
We have an EPICS support module for the MV2, including an asyn driver, which is deployed on a number of beamlines. I can send you some code for this.
The ASCII commands are straightforward and the device can be controlled easily through telnet for experimentation.
Dave
Dave  Hickin
Software Systems Engineer (EPICS)
Diamond Light Source
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: 13 January 2016 14:58
To: [email protected]
Subject: RGA MKS Microvision 2
Hello,
I am trying to figure out how control a Microvision 2 RGA with EPICS. This unit has an Ethernet interface but no obvious API. I understand that Microvision 2 units have been connected to EPICS at Diamond directly through their Ethernet without using a PC running MKS’s Process Eye.  Any help with this would be appreciated.
Rory Clarke
Rory Clarke
Electrical and Controls Systems Group
Daresbury Laboratory
Keckwick Lane
Warrington
Cheshire
WA4 4AD
Email: [email protected]
Attachment: microvision2.jpg
Description: microvision2.jpg
RE: RGA MKS Microvision 2 Mark Rivers
RE: RGA MKS Microvision 2 Heesterman, Peter J
RGA MKS Microvision 2 rory.clarke
RE: RGA MKS Microvision 2 david.hickin
Prev: Re: VxWorks 6.9 Andrew Johnson
Next: RE: RGA MKS Microvision 2 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: RGA MKS Microvision 2 david.hickin
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
