1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Would it be recommended to delete an asynPortDriver object when the IOC exits?
To: "EPICS Tech-Talk ([email protected])" <[email protected]>
Date: Thu, 14 Jan 2016 16:12:44 +0000
I invoke epicsAtExit to provide call-back notification that the IOC is exiting (in response to the user typing ‘exit’).
It seems to me good practice to delete the C++ IOC object, before the application exits, so as to prevent resource leaks.
(Rather than relying on the operating system to de-allocate.)
However, in my application , this results in unhandled access violation(s) after the object has been deleted (at least, in a debug build).
This occurs in the readInt32 call-back function, where it attempts to call pPvt->lock().
I believe this is caused by continued (threaded) scan polling of the record, after the object referenced has been destroyed.
It’s not a major problem.
Many thanks,
Peter.
RE: Would it be recommended to delete an asynPortDriver object when the IOC exits? Mark Rivers
Prev: areaDetector: ADBinX/Y and ADSizeX/Y interactions Phil Atkin
Next: Re: Skip updating an output link in aSub ? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: areaDetector: ADBinX/Y and ADSizeX/Y interactions Mark Rivers
Next: RE: Would it be recommended to delete an asynPortDriver object when the IOC exits? Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
