1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Would it be recommended to delete an asynPortDriver object when the IOC exits?
To: "'Heesterman, Peter J'" <[email protected]>, "EPICS Tech-Talk ([email protected])" <[email protected]>
Date: Thu, 14 Jan 2016 19:42:57 +0000
This is a tricky problem because EPICS is doing a callback with a pointer to the asynPortDriver object, but that object has now been deleted.  The destructor does not have access to that pointer that EPICS base is using, so it cannot set it to NULL to signify that the object has been deleted.
I think the solution is to add an epicsAtExit function in the base class which sets a “rebooting” flag.  If that flag is true then pPvt must be assumed to be invalid and all routines that use pPvt should immediately return before accessing pPvt.
From: [email protected] [mailto:[email protected]] On Behalf Of Heesterman, Peter J
Sent: Thursday, January 14, 2016 10:13 AM
To: EPICS Tech-Talk ([email protected])
Subject: Would it be recommended to delete an asynPortDriver object when the IOC exits?
I invoke epicsAtExit to provide call-back notification that the IOC is exiting (in response to the user typing ‘exit’).
It seems to me good practice to delete the C++ IOC object, before the application exits, so as to prevent resource leaks.
(Rather than relying on the operating system to de-allocate.)
However, in my application , this results in unhandled access violation(s) after the object has been deleted (at least, in a debug build).
This occurs in the readInt32 call-back function, where it attempts to call pPvt->lock().
I believe this is caused by continued (threaded) scan polling of the record, after the object referenced has been destroyed.
It’s not a major problem.
Many thanks,
Peter.
Would it be recommended to delete an asynPortDriver object when the IOC exits? Heesterman, Peter J
Prev: RE: areaDetector: ADBinX/Y and ADSizeX/Y interactions Mark Rivers
Next: RE: Device Support for I2C and GPIO Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Would it be recommended to delete an asynPortDriver object when the IOC exits? Heesterman, Peter J
Next: Re: Undefined symbol error when load VxWorks .much file Scott Baily
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
