1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Undefined symbol error when load VxWorks .much file
To: [email protected]
Date: Thu, 14 Jan 2016 09:41:21 -0700
I see your first question has been answered, but I'll answer the second question. Loading the file already tells you which symbol is undefined, so then you look at the libraries used to build the IOC and find which one refers to this symbol. Finding the undefined symbol without booting and loading the module is also useful. I wrote a simple perl script that runs nm, and finds all the undefined symbols in the munch file, then eliminates the ones that are defined in the kernel file. I use this script as part of the IOC build process for some of our IOCs, this way I can be alerted to undefined symbols before attempting to boot the IOC.
On 11/4/2015 2:09 PM, J. Lewis Muir wrote:
load("17lab.munch")
Undefined symbol: snprintf (binding 1 type 0)
ld error: Module contains undefined symbol(s) and may be unusable.
value = 0 = 0x0
Done executing startup script /ioc/boot/17lab/st.cmd
17lab>
--->8---
Does anyone know what's wrong or how to debug this?
I've tried running nmppc on 17lab.munch, but there are *many* symbols
prefixed with a 'U'.  In fact, when I run nmppc on a known-good .munch
file, it too shows many symbols prefixed with a 'U', so I'm not
confident I'm looking at the right thing.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
Prev: Re: Skip updating an output link in aSub ? Lingyun Yang
Next: Re: Skip updating an output link in aSub ? Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Would it be recommended to delete an asynPortDriver object when the IOC exits? Mark Rivers
Next: Keithley 7001 Scanner Support Jiro Fujita
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
