Hi Michael, I tried your ideal, but did not succeed. I may made mistakes, here is the sample code:record(aSub, "$(p)P") { field(INPA, "$(p)WF") field(NOA, "6") field(FTA, "DOUBLE") field(INPB, "$(p)WF:X") field(NOB, "6") field(FTB, "SHORT") field(OUTC, "$(p)TO1 NPP") field(FTVC, "DOUBLE") field(NOVC, "1") field(OUTD, "$(p)TO1.DISV PP") field(FTVD, "SHORT") field(NOVD, "1") field(OUTE, "$(p)TO2 NPP") field(FTVE, "DOUBLE") field(NOVE, "1") field(OUTF, "$(p)TO2.DISV PP") field(FTVF, "SHORT") field(NOVF, "1") field(OUTG, "$(p)TO3 NPP") field(FTVG, "DOUBLE") field(NOVG, "1") field(OUTH, "$(p)TO3.DISV PP") field(FTVH, "SHORT") field(NOVH, "1") field(SNAM, "splitMarkedVals") } Here is the Python test code and its output: # the initial three values caput(["l:TO1", "l:TO2", "l:TO3"], [10,20,30]) print caget(["l:TO1", "l:TO2", "l:TO3"]) # split this l:WF to TO1,TO2,TO3, using l:WF:X as mask caput("l:WF:X", [0, 1, 1]) caput("l:WF", [6, 5, 4]) caput("l:TO1.DISA", 0) caput("l:TO2.DISA", 0) caput("l:TO3.DISA", 0) print "initial TO1:", caget(["l:TO1", "l:TO1.DISV", "l:TO1.DISA"]) print "initial TO2:", caget(["l:TO2", "l:TO2.DISV", "l:TO2.DISA"]) print "initial TO3:", caget(["l:TO3", "l:TO3.DISV", "l:TO3.DISA"]) print caget(["l:TO1", "l:TO2", "l:TO3"]) caput("l:P.PROC", 1) # the result should be [6, 20, 30] or [10, 5, 4] # depending mask means drop or drop print "TO1", caget(["l:TO1", "l:TO1.DISV", "l:TO1.DISA"]) print "TO2", caget(["l:TO2", "l:TO2.DISV", "l:TO2.DISA"]) print "TO3", caget(["l:TO3", "l:TO3.DISV", "l:TO3.DISA"]) [10.0, 20.0, 30.0] initial TO1: [10.0, 0, 0] initial TO2: [20.0, 1, 0] initial TO3: [30.0, 1, 0] [10.0, 20.0, 30.0] TO1 [6.0, 0, 0] TO2 [5.0, 1, 0] TO3 [4.0, 1, 0] On Wed, Jan 13, 2016 at 10:43 PM, Michael Davidsaver <[email protected]> wrote: Hi Lingyun, -- ------------------
Lingyun YANG Skype Name: lingyun_zjdt
| ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
