1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Issues with building EDM on Debian 8 32bit
To: Michael Davidsaver <[email protected]>, [email protected]
Date: Thu, 14 Jan 2016 10:06:02 -0800
It is having an issue linking back to EPICS_BASE for some reason when I go to build it.I can create a symbolic from /usr1/local/epics/release/R3.14.12.5/base/include/cvtFast.h to /usr1/local/epics/extensions/include/edm/ . This worked but is not correct way of doing this as I have to add more and more include files. I have even exported EPICS_BASE:
export EPICS_BASE=/usr1/local/epics/release/R3.14.12.5/base/
But this also does not work. It must be something to do with my path that not getting set correctly, although I have this set in my /usr1/local/epics/extensions/configure/RELEASE file:
EPICS_EXTENSIONS=$(TOP)
I am trying to build EDM in the following directory:
/usr1/local/epics/extensions/src/edm
I am assuming there must be an issue with a path as /usr1/local/epics/release/R3.14.12.5/base/includes/cvtFast.h does exist.
Shawn
-I. -I../O.Common -I. -I.. -I../../../../include/edm/os/Linux
-I../../../../include/edm -I../../util -I../../lib
-I/lib/i386-linux-gnu -I/usr/lib/i386-linux-gnu
I'm puzzled that I don't see the path to EPICS Base here.  Specifically
you should see "-I$(EPICS_BASE) -I$(EPICS_BASE)/os/Linux" (expanded of
course).
However, the fast that make proceeds far enough to invoke the compiler
suggests that you have the correct path for EPICS_BASE.
../group.h:27:21: fatal error: cvtFast.h: No such file or directory
"cvtFast.h" comes from EPICS Base.  Does it exist for you as
"/usr1/local/epics/release/R3.14.12.5/base/include/cvtFast.h"?  If not
then Base is probably not build correctly.
FYI, a set of instructions which I've checked
http://mdavidsaver.github.io/epics-doc/epics-starting.html
On 01/13/2016 04:56 PM, Shawn Rapaz wrote:
Hello,
I have successfully built EPICS Base as well as EPICS extensions but I
cannot build EDM successfully. I am currently trying to build
edm-1-12-102. I have the following set:
/usr1/local/epics/extensions/configure/RELEASE:
OAG_APPS=$(TOP)/../../oag/apps
/usr1/local/epics/extensions/configure/os/CONFIG_SITE.linux-x86.linux-x86:
X11_LIB=/lib/i386-linux-gnu
X11_INC=/usr/lib/i386-linux-gnu
MOTIF_LIB=/usr/lib/i386-linux-gnu
MOTIF_INC=/lib/i386-linux-gnu
I also created a /usr/X11R6 directory with the following link:
 lib -> /lib/i386-linux-gnu
This is my export:
export EPICS_HOST_ARCH=linux-x86
When I try to build, I get the following error:
/usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_
-DUNIX  -Dlinux     -O3 -g   -Wall     -DSINGLE_THREADED=1
-D__epics__=1   -m32     -fPIC -MMD -I. -I../O.Common -I. -I..
-I../../../../include/edm/os/Linux -I../../../../include/edm
-I../../util -I../../lib -I/lib/i386-linux-gnu
-I/usr/lib/i386-linux-gnu    ../app_pkg.cc
In file included from ../bindings.h:27:0,
                 from ../act_win.h:44,
                 from ../app_pkg.h:36,
                 from ../app_pkg.cc:19:
 #include "cvtFast.h"
compilation terminated.
../../../../configure/RULES_BUILD:213: recipe for target 'app_pkg.o'
failed
make[2]: *** [app_pkg.o] Error 1
make[2]: Leaving directory
'/usr1/local/epics/extensions/src/edm-1-12-102/lib/O.linux-x86'
../../../configure/RULES_ARCHS:64: recipe for target
'install.linux-x86' failed
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory
'/usr1/local/epics/extensions/src/edm-1-12-102/lib'
../../configure/RULES_DIRS:87: recipe for target 'lib.install' failed
make: *** [lib.install] Error 2
Any advice or help would be much appreciated. Thank you in advance.
Shawn Rapaz
Shawn Rapaz
ISAC Controls Computer Systems Administrator, TRIUMF
4004 Wesbrook Mall, Vancouver, BC V6T 2A3
Phone: (604) 222-1047 (ext 6439)
Fax: (604) 222-1074
Issues with building EDM on Debian 8 32bit Shawn Rapaz
Re: Issues with building EDM on Debian 8 32bit Michael Davidsaver
Prev: Re: areaDetector: ADBinX/Y and ADSizeX/Y interactions Phil Atkin
Next: RE: areaDetector: ADBinX/Y and ADSizeX/Y interactions Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Issues with building EDM on Debian 8 32bit Michael Davidsaver
Next: Skip updating an output link in aSub ? Lingyun Yang
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
