1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gateway on machine with two network cards and running many IOCs?
To: "Hartman, Steven M." <[email protected]>
Date: Mon, 25 Jan 2016 09:18:23 +0000
Hi Steven,
Thanks for your reply.
As it turns out, we will have a server dedicated to running the archiver, so we'll try to use that for the gateway, and see how it goes, but we'll keep in mind the solution of using different ports.
Cheers,
Isabella
On 22 January 2016 at 14:40, Hartman, Steven M. <[email protected]> wrote:
> On Jan 22, 2016, at 7:15 AM, Isabella Rey <[email protected]> wrote:
> In an ideal world, I would like to have read-write access to PVs from any machine within the lab network, but read-only access from the site network.
Hello Isabella—
We implemented this by running the gateway on a non-standard port. The IOCs use the standard CA network ports and local clients connect that way for read/write access. The gateway provides read-only monitoring from the office network and clients there are configured to use the non-standard port. A perimeter firewall prevents the office network clients from reaching the IOCs on the standard ports. The gateway configuration prevents loops.
Steven Hartman
[email protected]
Re: Gateway on machine with two network cards and running many IOCs? Ralph Lange
Gateway on machine with two network cards and running many IOCs? Isabella Rey
Re: Gateway on machine with two network cards and running many IOCs? Hartman, Steven M.
Prev: Re: VxWorks 6.9 Andrew Johnson
Next: Re: Gateway on machine with two network cards and running many IOCs? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Gateway on machine with two network cards and running many IOCs? Hartman, Steven M.
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
