Since the first error is that it cannot find hdf5.h, that is the problem. You need to edit areaDetector/configure/CONFIG_SITE.local and define the path to your installation of hdf5. EXAMPLE_CONFIG_SITE.local shows an example of how to do it.
From: [email protected] [[email protected]] on behalf of 梁雅翔 [[email protected]]
Sent: Friday, January 29, 2016 8:18 AM
To: tech-talk
Subject: synApp or hdf5 wrong
Hi, everyone:
My environment: redhat server 6.0, base3.14.12.5.
Now I am making SynApps 5.8,there is something wrong.
The message( I have installed the hdf5, make install(success) but make install-check wrong ):
在包含自 ../napi.c:391 的文件中:
../napi5.h:6:18: warning:hdf5.h:no such directory of file
In file included from ../napi.c:391:
../napi5.h:50: Error:expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘attr_info’
../napi5.h:51: Error:expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute_’ before ‘group_info’
../napi5.h:52: Error:expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘nxgroup_info’
../napi.c: 在函数‘determineFileTypeImpl’中:
../napi.c:418: warning:implicit declarative function‘H5Fis_hdf5’
make[5]: *** [napi.o] error 1
make[5]: Leaving directory `/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2/ADApp/nexusSrc/O.linux-x86_64'
make[4]: *** [install.linux-x86_64] error 2
make[4]: Leaving directory `/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2/ADApp/nexusSrc'
make[3]: *** [nexusSrc.install] error 2
make[3]: Leaving directory `/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2/ADApp'
make[2]: *** [ADApp.install] error 2
make[2]: Leaving directory `/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2'
make[1]: *** [/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2.install] error 2
make[1]: Leaving directory `/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0'
make: *** [/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0.install] error 2
I tried to install hdf5 again, still be wrong.
(make install-check wrong and make synapp wrong)
Best regards,
Liang
- synApp or hdf5 wrong 梁雅翔
Re: BOY Linking Container doesn't support OPI Search Path? Pearson, Matthew R.
<2016>
2025
2026
help with SEQ record Christian Pauly
<2016>
2025
2026
