Hello... i use the pilatus detector...st.cmd ######################### Pilatus Detector START ###################################################### #epicsEnvSet("PREFIX", "BL5C") epicsEnvSet("PILPORT", "PIL") epicsEnvSet("QSIZE", "20") epicsEnvSet("XSIZE", "487") epicsEnvSet("YSIZE", "195") epicsEnvSet("NCHANS", "2048") epicsEnvSet("CAMSERVER", "10.0.1.100") ### # Create the asyn port to talk to the Pilatus on port 41234. drvAsynIPPortConfigure("camserver","$(CAMSERVER):41234") # Set the input and output terminators. asynOctetSetInputEos("camserver", 0, "\030") asynOctetSetOutputEos("camserver", 0, "\n") drvAsynIPPortConfigure("camserver","10.0.1.100:41234<http://10.0.1.100:41234><http://10.0.1.100:41234>") #asynSetTraceIOMask("camserver", 0, 2) #asynSetTraceMark("camserver",0,9) pilatusDetectorConfig("$(PILPORT)", "camserver", $(XSIZE), $(YSIZE), 50, 200000000) dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/ADBase.template", "P=$(PREFIX):,R=cam1:,PORT=$(PILPORT),ADDR=0,TIMEOUT=1") dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDFile.template", "P=$(PREFIX):,R=cam1:,PORT=$(PILPORT),ADDR=0,TIMEOUT=1") dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/pilatus.template","P=$(PREFIX):,R=cam1:,PORT=$(PILPORT),ADDR=0,TIMEOUT=1,CAMSERVER_PORT=camserver") # Create a standard arrays plugin NDStdArraysConfigure("Image1", 5, 0, "$(PILPORT)", 0, -1) dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDPluginBase.template","P=$(PREFIX):,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PILPORT),NDARRAY_ADDR=0") dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDStdArrays.template", "P=$(PREFIX):,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=94965") asynSetTraceMask("$(PORT)",0,255) # Load all other plugins using commonPlugins.cmd < ../commonPlugins.cmd ############################################################################################### Can you tell me What is wrong? Best Regards. mujin
| ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
