Hi Mujin,
What version of areaDetector are you using?
You have showed us part of your startup script. What we really need to see is the console output when you execute that startup script.
Your script contains these commands:
# Load all other plugins using commonPlugins.cmd
< ../commonPlugins.cmd
I suspect that command is generating an error.
At the IOC prompt you can also type the command "dbl" to see a list of records loaded. That will tell you if perhaps the plugins were loaded with the wrong PREFIX or something.
From: [email protected] [[email protected]] on behalf of mujin park [[email protected]]
Sent: Thursday, February 18, 2016 2:13 AM
To: [email protected]
Subject: Pilatus plugins is not available...
Hello...
i use the pilatus detector...
i had setuped a pilatus ioc
but Plugins' pv is not Ok...
Only $(PREFIX):Image1:... 's pv is available..
st.cmd
######################### Pilatus Detector START ######################################################
#epicsEnvSet("PREFIX", "BL5C")
epicsEnvSet("PILPORT", "PIL")
epicsEnvSet("QSIZE", "20")
epicsEnvSet("XSIZE", "487")
epicsEnvSet("YSIZE", "195")
epicsEnvSet("NCHANS", "2048")
epicsEnvSet("CAMSERVER", "10.0.1.100")
# Create the asyn port to talk to the Pilatus on port 41234.
drvAsynIPPortConfigure("camserver","$(CAMSERVER):41234")
# Set the input and output terminators.
asynOctetSetInputEos("camserver", 0, "\030")
asynOctetSetOutputEos("camserver", 0, "\n")
drvAsynIPPortConfigure("camserver","10.0.1.100:41234<http://10.0.1.100:41234><http://10.0.1.100:41234><http://10.0.1.100:41234>")
#asynSetTraceIOMask("camserver", 0, 2)
#asynSetTraceMark("camserver",0,9)
pilatusDetectorConfig("$(PILPORT)", "camserver", $(XSIZE), $(YSIZE), 50, 200000000)
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/ADBase.template", "P=$(PREFIX):,R=cam1:,PORT=$(PILPORT),ADDR=0,TIMEOUT=1")
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDFile.template", "P=$(PREFIX):,R=cam1:,PORT=$(PILPORT),ADDR=0,TIMEOUT=1")
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/pilatus.template","P=$(PREFIX):,R=cam1:,PORT=$(PILPORT),ADDR=0,TIMEOUT=1,CAMSERVER_PORT=camserver")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "$(PILPORT)", 0, -1)
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDPluginBase.template","P=$(PREFIX):,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PILPORT),NDARRAY_ADDR=0")
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDStdArrays.template", "P=$(PREFIX):,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=94965")
asynSetTraceMask("$(PORT)",0,255)
i can't see the areaDetector plugins is not working..
they are blank...
Can you tell me What is wrong?
Best Regards.
mujin
- Pilatus plugins is not available... mujin park
pv monitor... mujin park
RE: pv monitor... Mark Rivers
<2016>
2025
2026
does not exist, sCalcout.c 梁雅翔
<2016>
2025
2026
