1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OSI Compliant VME Support
To: Michael Davidsaver <[email protected]>, Matt Rippa <[email protected]>, EPICS tech-talk <[email protected]>
Date: Wed, 24 Feb 2016 11:47:45 -0600
Hi Michael,
On 02/23/2016 10:38 PM, Michael Davidsaver wrote:
> https://github.com/mdavidsaver/xycomioc
> Support for 220, 240, and 566 cards.  Tested with RTEMS and vxWorks.
> Can't remember how feature complete.  Other than checking that it builds
> just now, I haven't looked at it since 2010.  This code holds some
> sentimental value to me as it's one of my first epics drivers, and the
> only one I found a good name for.
Nothing against your drivers, but Matt should understand that they were
not derived from the xycom drivers that were included with Base-3.13.x
and earlier. IIRC the original xycom digital drivers had a slightly
unexpected mapping between the signal address and I/O channels (S0 is
not port 0 bit 0). The xy240 driver also has a background thread that
emulates I/O Interrupt scanning.
I suspect Matt has existing applications that expect the original
capabilities, so compatibility may be important to him.
- Andrew
There are only two hard problems in distributed systems:
  2. Exactly-once delivery
  1. Guaranteed order of messages
 -- Mathias Verraes
Re: OSI Compliant VME Support Matt Rippa
Re: OSI Compliant VME Support Andrew Johnson
Re: OSI Compliant VME Support Michael Davidsaver
Prev: Re: EPICS CA Interface for caQtDM and epicsqt Mezger Anton Christian (PSI)
Next: Re: OSI Compliant VME Support Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OSI Compliant VME Support Michael Davidsaver
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
