1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about archive
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 4 Mar 2016 12:48:59 +0100
Small comment:
I would suggest to *never* put the IOC name into a record name.
Which IOC a specific PV is served from is an implementation detail that is irrelevant to the user/client and should not be exposed.
Consider that you have to move the record to a different IOC, e.g. because you split up an IOC after it hits some resource limits.
Will you be renaming all PVs as you move them? Will you keep the names that are now misleading? This is a recipe for trouble.
BTW: The same applies to putting the record type (ai, bi, ...) into the record name. If you ever want to change the implementation (e.g. use a mbbi instead of a bi because you define additional states), your names will be wrong or have to be changed.
Just my 2cts...
~Ralph
On 04/03/2016 11:21, Mazanec Tomáš wrote:
Hi
What if you create a scheme for PVs naming which will include information about system and device ?
Something like naming convention for PVs, e.g.:
$(SYSTEM)-$(DEVICE)-$(IOC):Current_Setpoint
where:
SYSTEM=MAGNETS2
DEVICE=PSU
IOC=POW-CNTRL
So you don't have to program extra stuff to EPICS/CA applications.
Tomas
Od: [email protected] [[email protected]] za uživatele 岳敏 [[email protected]]
Odesláno: 4. března 2016 10:10
Komu: [email protected]
Předmět: question about archive
Hi, everyone
       I have a question about Archive. In CSS, I select Archive Search then I can see a table including "PV Name" and "Name" . But some CSS user in our team want to see the device name which the "PV Name"  belongs to. I know that the  "PV Name" list is from a XML file. How can I add one column in the XML file or can I do some special setting in the CSS to realize 3 columns dispay in the  Archive Search panel?
    Min Yue
Institute of Modern Physics, Chinese Academy of Sciences
509 Nanchang Road, Lanzhou, 730000, P.R.China
Tel:+86-0931-4969469
Handy: +86-18509316383
question about archive 岳敏
RE: question about archive Mazanec Tomáš
Prev: CSS 4.1: performance drop when using linking container and macros Zumbruch, Peter Dr.
Next: Re: generic CSS version Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: question about archive Mazanec Tomáš
Next: Re: question about archive Kasemir, Kay
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
