1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about archive
To: 岳敏 <[email protected]>
Date: Fri, 4 Mar 2016 13:58:12 +0000
On Mar 4, 2016, at 4:10 AM, 岳敏 <[email protected]> wrote:
Hi, everyone
       I have a question about Archive. In CSS, I select Archive Search then I can see a table including "PV Name" and "Name" . But some CSS user in our team want to see the device name which the "PV Name"  belongs to. I know that the  "PV Name" list is from a XML file.
The archive search panel searches for channels in an archive data source.
Archive data sources can be
1) Old channel archiver’s XML-RPC data server (not recommended at this time)
2) RDB-based archive described in the CSS dock
3) SLAC Archiver Appliance
4) Your own archive data server if you implement the ‘*.archive.reader.*” interface
In any case, you get the channel names.
Not the “device”, not the author of the record, not ..
How can I add one column in the XML file or can I do some special setting in the CSS to realize 3 columns dispay in the  Archive Search panel?
You might refer to the XML file that approaches 1, 2, and 3 use to configure their archive engines.
Still, that’s just channel names.
If you want to store more information with a ‘channel’, like “device”, beam line location, author of the record, .., look for information on the “Channel Finder”.
See EPICS meeting reports.
-Kay
question about archive 岳敏
Prev: Re: generic CSS version Konrad, Martin
Next: RE: CSS 4.1: performance drop when using linking container and macros Mark S. Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: question about archive Ralph Lange
Next: CSS 4.1: performance drop when using linking container and macros Zumbruch, Peter Dr.
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
