1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mrfioc2 error at uTCA platform
To: "Konrad, Martin" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 7 Mar 2016 20:21:45 +0000
Hi Martin,
>> PMC EVR on a PMC carrier card, right?
Yes, right! Vadatech PMC Carier board.
>>What does "lspci" say? Maybe you've plugged the card into a different AMC slot?
I think slot is correct slot number because it worked before.
 Here is a PMC-EVR-230 with VID:DID 10b5:9030 and subvendor ID 1a3e
and subvendor device ID 11e6. (JUkka already confirmed )
[root@amc725 mrf_pci_driver]# lspci -nn -x
0e:01.0 Signal processing controller [1180]: PLX Technology, Inc. PCI9030 32-bit 33MHz PCI <-> IOBus Bridge [10b5:9030] (rev 01)
00: b5 10 30 90 02 00 90 02 01 00 80 11 08 00 00 00
10: 00 00 a1 fd 00 00 00 00 00 00 a0 fd 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 3e 1a e6 11
30: 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
Interesting is the SLAC evr version is correctly working.
evrIocTest_registerRecordDeviceDriver(pdbbase)
ErConfigure(0, 0, 0, 0, 1)
EvrOpen, device = /dev/era3
EVR Found with Firmware Revision 0x11000007
Found a PMC_EVR /dev/era3
Jihwa
보낸 사람: Konrad, Martin <[email protected]>
보낸 날짜: 2016년 3월 7일 월요일 오후 1:37
받는 사람: 김지화(빔라인장치팀); [email protected]
제목: Re: mrfioc2 error at uTCA platform
Hi Jihwa,
 > Dose any one has experience of mrfioc2 evr driver for uTCA platform?
> PMC-EVR-230 firmware version: PMC-EVR-230-11000007.bit
I guess you are not using the native uTCA card but a PMC EVR on a PMC
> mrmEvrSetupPCI("PMCEVR",0xe,1,0)
> Device PMCEVR 14:1.0
> Using IRQ 16
> Failed to open uio device for PCI device 0000:0e:01.0: No such file or
> directory
> Failed to enable interrupt
AMC slot?
-Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: mrfioc2 error at uTCA platform Michael Davidsaver
Re: mrfioc2 error at uTCA platform Konrad, Martin
Prev: Re: Problem in running simple tutorial problems Matt Newville
Next: Re: mrfioc2 error at uTCA platform Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mrfioc2 error at uTCA platform Konrad, Martin
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
