Hi Ralph,
I assume you are alluding to the record field property
"promptgroup" which can take a set of "gui_group" values according
to the Application Developer's guide.
Our tdct tool ( http://isacwserv.triumf.ca/epics/tdct/), the fully
Capfast-compatible database configuration tool relies on
promptgroup:
- tdct uses the existence of the promptgroup property for a
field in the record's dbd definition as an indication that the
field can be configured by tdct.
- tdct does *not yet* use the value of the promptgroup
property, as these seem to be assigned somewhat arbitrarily.
Here at TRIUMF, we would be extremely vulnerable to
dbd-dbd-changes which are not fully backward-compatible for the
following reason:
From the outset we have designed our IOC databases making
extensive use of the Capfast (and now tdct) hierarchical
capabilities. We use several layers of hierarchy of re-usable
components to build up our device functionality. As one
draw-back of this approach, we cannot package a specific IOC
database with a specific dbd file. Our components show up in
every IOC across EPICS releases. For example, we still maintain
some 3.13 legacy IOCs.
I assume several other labs who use Capfast or migrated from
Capfast to tdct are in the same boat.
HTH - rolf -
On 3/8/2016 12:07 AM, Ralph Lange wrote:
Dear All,
Before seriously considering a redesign of the gui_group()
properties in record definitions (intended as hints to DB
configuration tools to provide a comprehensively grouped view of a
record's fields), an important question:
Are there any tools or mechanisms in use (other than VDCT)
that use the gui_group() properties and might be broken?
Please point out any usage of this feature. (In case you know, add
the way it is used: discovered from DBD file, using the header
file from base, hard coded, ...)
Thanks a lot,
~Ralph
| Rolf Keitel, Ph.D. Tel: (604) 222-7453 |
| TRIUMF |
| Vancouver, B.C., Canada |
- Re: Q: Are any tools using gui_group() properties? Ralph Lange
- Q: Are any tools using gui_group() properties? Ralph Lange
RE: EpicsQt compile problems rory.clarke
OpenCV experience? (Windows VS2015 / C++) Stein, S. Joshua
<2016>
2025
2026
<2016>
2025
2026
ANJ, 15 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
