1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IoC support for Rohde & Schwarz SMA100A
To: [email protected]
Date: Wed, 9 Mar 2016 17:58:19 +0100
Hello,
starting from a Benjamin (Bessy) version I made my stream proto which follow :
# INFN - LNL
# Protocol file to Rohde&Schwarz SMA100A
# Author: Mauro Giacchini
# Email : [email protected]
# Based on previous version from Benjamin (BESSY)
# Communication setup
OutTerminator = CR LF;
InTerminator = LF;
ExtraInput = Ignore;
setupSweepMode {
    out "SOUR:SWE:FREQ:MODE STEP";
    out "SOUR:SWE:FREQ:SPAC LIN";
    out "TRIG:FSW:SOUR EXT";
inFrq {
    out "FREQ?";
    in "%f";
outFrq {
    out "FREQ %f";
    @init { inFrq; };
inStartFrq {
    out "FREQ:STAR?";
    in "%f";
outStartFrq {
    out "FREQ:STAR %f";
    @init { inStartFrq; };
inStopFrq {
    out "FREQ:STOP?";
    in "%f";
outStopFrq {
    out "FREQ:STOP %f";
    @init { inStopFrq; };
inStepFrq {
    out "SWE:FREQ:STEP:LIN?";
    in "%f";
outStepFrq {
    out "SWE:FREQ:STEP:LIN %f";
    @init { inStepFrq; };
inLvl {
    out "LEVEL?";
    in "%f"
outLvl {
    out "LEVEL %f";
    @init { inLvl; };
inFmFrq {
    out "FM?";
    in "%f"
outFmFrq {
    out "FM %f";
    @init { inFmFrq; };
# get identification
inIdn {
    out "*IDN?";
    in "%s";
# reset to default state
outRst {
    out "*RST; *WAI";
# phase continuous frequency setting
inPhasCont {
    out "FREQ:PHAS:CONT:STAT?";
    in "%i";
outPhasCont {
    out "FREQ:PHAS:CONT:STAT %{OFF|ON}";
    @init { inPhasCont; }
# for quickly testing new commands and queries
test {
    out "%s"; in "%39c"
inFrqMode {
    out "FREQ:MODE?";
    in  "%{CW|SWE|LIST}";
outFrqMode {
    setupSweepMode;
    out "FREQ:MODE %{CW|SWE|LIST}";
    @init {
        setupSweepMode;
        inFrqMode;
# Read the RF status  pag 390
inRFStat {
    out "OUTP?";
    in "%i";
# Set the RF status  pag 390
outRFStat {
    out "OUTP %{OFF|ON}";
    @init { inRFStat; };
# Read the RF output level pag. 560
inRFLevel {
    out "SOUR:POW:LEV:IMM:AMPL?";
    in "%f";
# Set the RF output level pag. 560
outRFLevel {
    out "SOUR:POW:LEV:IMM:AMPL %f";
    @init { inRFLevel; };
# storing current setting like set0.txt
strSet0 {
    out "*SAV 0";
    out "MMEM:STOR:STAT 0, '/var/user/pwrtests/set0.txt'";
# Store current SMA100A configuration on file selected by $1:setupFileName.VAL
strSetup {
    out "*SAV 0";
    out "MMEM:STOR:STAT 0, '/var/user/pwrtests/%(\$1:setupFileName.VAL)s.txt'";
# Load current SMA100A configuration on file selected by $1:setupFileName.VAL
lodSetup {
    out "MMEM:LOAD:STAT 0, '/var/user/pwrtests/%(\$1:setupFileName.VAL)s.txt'";
    out "*RCL 0";
# loading current setting like set0.txt
lodSet0 {
    out "MMEM:LOAD:STAT 0, '/var/user/pwrtests/set0.txt'";
    out "*RCL 0";
# storing current setting like set1.txt
strSet1 {
    out "*SAV 1";
    out "MMEM:STOR:STAT 1, '/var/user/pwrtests/set1.txt'";
lodSet1 {
    out "MMEM:LOAD:STAT 1, '/var/user/pwrtests/set1.txt'";
    out "*RCL 1";
# Read the amplitude modulation status pag.457
inAMState {
    out "SOUR:AM:STAT?";
        in "%i"
# Set the amplitude modulation status pag.457
outAMState {
    out "SOUR:AM:STAT %{OFF|ON}";
    @init { inAMState; };
# Read the amplitude modulation source pag.456
inAMSour {
    out "SOUR:AM:SOUR?";
    in  "%{INT|EXT}";
# Set the amplitude modulation source pag.456
outAMSour {
    out "SOUR:AM:SOUR %{INT|EXT}";
    @init { inAMSour; };
# Read the amplitude modulation source pag.455
inAMSourInt {
    out "SOUR:AM:INT:SOUR?";
    in  "%#{LF12=2|NOIS=3|LF1N=4|LF2N=5|LF1=0|LF2=1}";
# Set the amplitude modulation source pag.455
outAMSourInt {
     out "SOUR:AM:INT:SOUR %{LF1|LF2|LF12|NOIS|LF1N|LF2N}";
     @init { inAMSourInt; };
# Read the pulse generation status pag.560
inPGState {
    out "SOUR:PGEN:STAT?";
        in "%i"
# Set the pulse generation status pag.560
outPGState {
    out "SOUR:PGEN:STAT %{OFF|ON}";
    @init { inPGState; };
# Read the frequency modulation status pag.496
inFMState {
    out "SOUR:FM:STAT?";
        in "%i"
# Set the frequency modulation status pag.496
outFMState {
    out "SOUR:FM:STAT %{OFF|ON}";
    @init { inFMState; };
# Read the frequency of the LF output generator pag.526
inLFFrq {
    out "SOUR:LFO%(\$1:inc.VAL)s:FREQ?";
        in "%i"
outLFFrq {
    out "SOUR:LFO%(\$1:inc.VAL)s:FREQ %i";
#    @init { wait 500; inLFFrq; };
# Read the shape of the LF output generator pag.535
inLFShap {
    out "SOUR:LFO%(\$1:inc.VAL)s:SHAP?";
    in  "%{SINE|SQU|TRI|TRAP}";
# Set the shape of the LF output generator pag.535
outLFShap {
    out "SOUR:LFO%(\$1:inc.VAL)s:SHAP %{SINE|SQU|TRI|TRAP}";
#    @init { inLFShap; };
# Read the frequency modulation source pag.499
inFMSour {
    out "SOUR:FM:SOUR?";
    in  "%#{INT,EXT=2|EXT=1|INT=0|EDIG=3}";
# Set the frequency modulation source pag.499
outFMSour {
     out "SOUR:FM:SOUR %{INT|EXT|INT,EXT|EDIG}";
     @init { inFMSour; };
# Read the frequency modulation sensitivity pag.499
inFMSens {
    out "SOUR:FM:SENS?";
        in "%f"
# Read the frequency modulation mode pag.498
inFMMode {
    out "SOUR:FM:MODE?";
    in  "%#{NORM|LNO}";
# Set the frequency modulation mode pag.498
outFMMode {
    out "SOUR:FM:MODE %{NORM|LNO}";
    @init { inFMMode; };
# Read the frequency modulation deviation pag.496
inFMDev {
    out "SOUR:FM:DEV?";
    in  "%i"
# Set the frequency modulation deviation pag.496
outFMDev {
    out "SOUR:FM:DEV %i";
    @init { inFMDev; };
# Read the pulse modulation status pag.581
inPMState {
    out "SOUR:PULM:STAT?";
        in "%i"
# Set the pulse modulation status pag.581
outPMState {
    out "SOUR:PULM:STAT %{OFF|ON}";
    @init { inPMState; };
# Read the pulse modulation width pag.591
inPMWidt {
    out "SOUR:PULM:WIDTH?";
        in "%f"
# Set the pulse modulation width pag.591
outPMWidt {
    out "SOUR:PULM:WIDTH %f";
    @init { inPMWidt; };
# Read the pulse modulation polarity pag.580
inPMPol {
    out "SOUR:PULM:POL?";
    in  "%{NORM|INV}";
# Set the pulse modulation polarity pag.580
outPMPol {
    out "SOUR:PULM:POL %{NORM|INV}";
    @init { inPMPol; };
# Read the pulse modulation period pag.579
inPMPer {
    out "SOUR:PULM:PER?";
        in "%f"
# Set the pulse modulation period pag.579
outPMPer {
    out "SOUR:PULM:PER %f";
    @init { inPMPer; };
# Read the pulse modulation mode pag.579
inPMMod {
    out "SOUR:PULM:MODE?";
    in  "%{SING|DOUB|PTR}";
# Set the pulse modulation mode pag.579
outPMMod {
    out "SOUR:PULM:MODE %{SING|DOUB|PTR}";
    @init { inPMMod; };
# Read the modulation subsystems status pag.557
inMOStat {
    out "SOUR:MOD:ALL:STAT?";
    in  "%i";
# Set the modulation subsystems status pag.557
outMOStat {
    out "SOUR:MOD:ALL:STAT %{OFF|ON}";
    @init { inMOStat; };
# Set the instrument on LOCAL operation mode pag.323
Local {
    out "%{|&GTL}";
# Refresh the value of ao/bo records after the switch between local -to- remote of $(DEV):LocRmt
Refresh {
    out "FREQ?";
    in "%(\$1:ConvValues.DO1)f";                                                # pointer to record $(DEVN):outRfq
    in "%(\$1:ConvValues.DO2)f";                                                # pointer to record $(DEVN):outPMWidt
    in "%(\$1:ConvValues.DO3)f";                                                # pointer to record $(DEVN):outPMPer
    in "%(\$1:ConvValues.DO4)f";                                                # pointer to record $(DEVN):outLFFrq
        in  "%(\$1:ConvValues.DO5){SINE|SQU|TRI|TRAP}";         # pointer to record $(DEVN):outLFShap
        in "%(\$1:ConvValues.DO6)f";                                            # pointer to record $(DEVN):outRFlevel
        out "OUTP?";
        in "%(\$1:ConvValues.DO7)i";                                            # pointer to record $(DEVN):outRFstat
On 3/9/2016 5:20 PM, Vitor Finotti wrote:
Hello all,
I need to control a SMA100A signal generator through EPICS. Have anyone already done the respective IoC? Thanks!
HTH,
-Mauro
________________________________________________________________________
Mauro Giacchini
Control Systems Specialist
INFN Laboratori Nazionali di Legnaro
Viale Università 2
I 35020 Legnaro (Padova)
Tel. +39 049 8068 558
Fax               558
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
...the first EPICS installation to the project SPES realized from the
scratch in ITALY is in production since begin 2010!!
This email is safe. www.avast.com
IoC support for Rohde & Schwarz SMA100A Vitor Finotti
Prev: Re: Kohzu motors poll rate issue?? Alireza Panna
Next: RE: Kohzu motors poll rate issue?? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IoC support for Rohde & Schwarz SMA100A Vitor Finotti
Next: Re: IoC support for Rohde & Schwarz SMA100A Eric Norum
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
