1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mbbo/mbbi and bits subset
To: [email protected]
Date: Thu, 10 Mar 2016 11:54:05 +0100 (CET)
I'm using mbbo and mbbi record types to write and read
some registers from/to ASYN driver I'm developing;
some registers refers to a single aspect of acquisition
(e.g. channel threshold) and with a simple mbbo record
to write and a mbbi record to read back, everything works
fine...
other registers refers to a setup/control functions
and using the same mbbo/mbbi approach works fine if
the user address (read/write) every time the whole register;
I know mbboDirect for bitwise access of a record value but
is there a method to address (read/write) through a record
a "bits subset" of a "main" mbbo record ?
e.g. acquisition control:
        bit[16...2]	<don't care>
	bit[1...0]
	  11		stop acquisition
	  10		start acquisition
	  01		do something...
	  00 		do something...
which is a simple method to access "directly" bitset [0...1]
in order to have a record I can use to write 11 (3) to stop acquisition,
10 (2) to start acquisiton and so on ?
Thanks in advance,
Gennaro
Gennaro Tortone
INFN Napoli
Italy
tel: +39 81 676169
"Computer Science is no more about computers
    than astronomy is about telescopes."
    - Edsger Dijkstra
RE: mbbo/mbbi and bits subset Mark Rivers
RE: mbbo/mbbi and bits subset peter.owens
Prev: RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
Next: RE: mbbo/mbbi and bits subset Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: In search of BIC 1000C current integrator manual Brian McAllister
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
