1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mrfioc2 error at uTCA platform
To: Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 10 Mar 2016 02:53:26 +0000
Hi Michael,
Here is a uTca message and kernel version information.
 [root@amc725 opt]#dmesg
 Event Receiver PCI/PCIe driver init.
 pci_mrfevr 0000:0e:01.0: enabling device (0140 -> 0142)
 mrfevr:BAR0 start fda10000 end fda1007f, mmap 02866000
 mrfevr:BAR2 start fda00000 end fda0ffff, mmap 135a0000
var(devPCIDebug, 5)
 mrmEvrSetupPCI("PMCEVR",0xe,1,0)
 linuxDevPCIInit found 0000:00:00.0
  as pri 8086:0104 sub 8086:0104 cls 060000
 linuxDevPCIInit found 0000:00:01.0
  as pri 8086:0101 sub 8086:0101 cls 060400
 linuxDevPCIInit found 0000:00:06.0
  as pri 8086:010d sub 8086:010d cls 060400
 linuxDevPCIInit found 0000:00:1d.0
  as pri 8086:2334 sub 8086:2334 cls 0c0320
 linuxDevPCIInit found 0000:00:1f.0
  as pri 8086:2310 sub 8086:2310 cls 060100
 linuxDevPCIInit found 0000:00:1f.2
  as pri 8086:2323 sub 8086:2321 cls 010601
 linuxDevPCIInit found 0000:00:1f.3
  as pri 8086:2330 sub 8086:2330 cls 0c0500
 linuxDevPCIInit found 0000:00:1f.6
  as pri 8086:2332 sub 8086:2332 cls 118000
 linuxDevPCIInit found 0000:00:1f.7
  as pri 8086:2360 sub a910:8e10 cls 088000
 linuxDevPCIInit found 0000:01:00.0
  as pri 10b5:8764 sub 10b5:8764 cls 060400
 linuxDevPCIInit found 0000:02:04.0
 linuxDevPCIInit found 0000:02:05.0
 linuxDevPCIInit found 0000:02:08.0
 linuxDevPCIInit found 0000:02:09.0
 linuxDevPCIInit found 0000:02:0a.0
 linuxDevPCIInit found 0000:02:0b.0
 linuxDevPCIInit found 0000:02:0c.0
 linuxDevPCIInit found 0000:05:00.0
  as pri 10b5:8649 sub 10b5:8649 cls 060400
 linuxDevPCIInit found 0000:06:00.0
 linuxDevPCIInit found 0000:06:01.0
 linuxDevPCIInit found 0000:06:02.0
 linuxDevPCIInit found 0000:06:10.0
 linuxDevPCIInit found 0000:06:11.0
 linuxDevPCIInit found 0000:06:12.0
 linuxDevPCIInit found 0000:06:13.0
 linuxDevPCIInit found 0000:06:14.0
 linuxDevPCIInit found 0000:06:15.0
 linuxDevPCIInit found 0000:06:16.0
 linuxDevPCIInit found 0000:06:17.0
 linuxDevPCIInit found 0000:14:00.0
  as pri 1b4b:9230 sub 1b4b:9230 cls 010601
 linuxDevPCIInit found 0000:15:00.0
  as pri 126f:0750 sub 126f:0750 cls 030000
 linuxDevPCIInit found 0000:16:00.0
  as pri 8086:0434 sub 8086:0000 cls 0b4000
 linuxDevPCIInit found 0000:16:00.1
  as pri 8086:043c sub 8086:0000 cls 020000
 linuxDevPCIInit found 0000:16:00.2
 linuxDevPCIInit found 0000:16:00.3
  as pri 8086:0438 sub 8086:0000 cls 020000
 linuxDevPCIInit found 0000:16:00.4
 linuxDevPCIInit found 0000:17:00.0
  as pri 8086:10fb sub ffff:ffff cls 020000
 linuxDevPCIInit found 0000:17:00.1
 linuxDevPCIInit found 0000:0c:00.0
  as pri abcd:7028 sub abcd:7523 cls 058000
 linuxDevPCIInit found 0000:0d:00.0
  as pri abcd:4105 sub 0000:0000 cls 060400
 linuxDevPCIInit found 0000:0e:01.0
  as pri 10b5:9030 sub 1a3e:11e6 cls 118000
 Consider 0:0.0
  0 mismatch device 9030 104
  1 mismatch device 9030 104
  2 mismatch device 9056 104
 Consider 0:1.0
  0 mismatch device 9030 101
  1 mismatch device 9030 101
  2 mismatch device 9056 101
 Consider 0:6.0
  0 mismatch device 9030 10d
  1 mismatch device 9030 10d
  2 mismatch device 9056 10d
 Consider 0:29.0
  0 mismatch device 9030 2334
  1 mismatch device 9030 2334
  2 mismatch device 9056 2334
 Consider 0:31.0
  0 mismatch device 9030 2310
  1 mismatch device 9030 2310
  2 mismatch device 9056 2310
 Consider 0:31.2
  0 mismatch device 9030 2323
  1 mismatch device 9030 2323
  2 mismatch device 9056 2323
 Consider 0:31.3
  0 mismatch device 9030 2330
  1 mismatch device 9030 2330
  2 mismatch device 9056 2330
 Consider 0:31.6
  0 mismatch device 9030 2332
  1 mismatch device 9030 2332
  2 mismatch device 9056 2332
 Consider 0:31.7
  0 mismatch device 9030 2360
  1 mismatch device 9030 2360
  2 mismatch device 9056 2360
 Consider 1:0.0
  0 mismatch device 9030 8764
  1 mismatch device 9030 8764
  2 mismatch device 9056 8764
 Consider 2:4.0
 Consider 2:5.0
 Consider 2:8.0
 Consider 2:9.0
 Consider 2:10.0
 Consider 2:11.0
 Consider 2:12.0
 Consider 5:0.0
  0 mismatch device 9030 8649
  1 mismatch device 9030 8649
  2 mismatch device 9056 8649
 Consider 6:0.0
 Consider 6:1.0
 Consider 6:2.0
 Consider 6:16.0
 Consider 6:17.0
 Consider 6:18.0
 Consider 6:19.0
 Consider 6:20.0
 Consider 6:21.0
 Consider 6:22.0
 Consider 6:23.0
 Consider 20:0.0
  0 mismatch device 9030 9230
  1 mismatch device 9030 9230
  2 mismatch device 9056 9230
 Consider 21:0.0
  0 mismatch device 9030 750
  1 mismatch device 9030 750
  2 mismatch device 9056 750
 Consider 22:0.0
  0 mismatch device 9030 434
  1 mismatch device 9030 434
  2 mismatch device 9056 434
 Consider 22:0.1
  0 mismatch device 9030 43c
  1 mismatch device 9030 43c
  2 mismatch device 9056 43c
 Consider 22:0.2
 Consider 22:0.3
  0 mismatch device 9030 438
  1 mismatch device 9030 438
  2 mismatch device 9056 438
 Consider 22:0.4
 Consider 23:0.0
  0 mismatch device 9030 10fb
  1 mismatch device 9030 10fb
  2 mismatch device 9056 10fb
 Consider 23:0.1
 Consider 12:0.0
  0 mismatch device 9030 7028
  1 mismatch device 9030 7028
  2 mismatch device 9056 7028
 Consider 13:0.0
  0 mismatch device 9030 4105
  1 mismatch device 9030 4105
  2 mismatch device 9056 4105
 Consider 14:1.0
  0 Match
 Device PMCEVR  14:1.0
 Using IRQ 16
 Looking for UIO dir in /sys/bus/pci/devices/0000:0e:01.0/ with uio:uio%u
  Check . gives 0 32766
  Check .. gives 0 32766
  Check irq gives 0 32766
  Check vpd gives 0 32766
  Check subsystem_vendor gives 0 32766
  Check broken_parity_status gives 0 32766
  Check class gives 0 32766
  Check power gives 0 32766
  Check reset gives 0 32766
  Check resource gives 0 32766
  Check consistent_dma_mask_bits gives 0 32766
  Check modalias gives 0 32766
  Check dma_mask_bits gives 0 32766
  Check local_cpus gives 0 32766
  Check config gives 0 32766
  Check device gives 0 32766
  Check driver gives 0 32766
  Check enable gives 0 32766
  Check subsystem gives 0 32766
  Check msi_bus gives 0 32766
  Check local_cpulist gives 0 32766
  Check remove gives 0 32766
  Check rescan gives 0 32766
  Check uevent gives 0 32766
  Check vendor gives 0 32766
  Check resource0 gives 0 32766
  Check resource2 gives 0 32766
  Check subsystem_device gives 0 32766
  Check numa_node gives 0 32766
  Check d3cold_allowed gives 0 32766
 Looking for UIO dir in /sys/bus/pci/devices/0000:0e:01.0/uio/ with uio%u
 Failed to open uio device for PCI device 0000:0e:01.0: No such file or directory
 Failed to enable interrupt
 [root@amc725 0000:0e:01.0]# cd /sys/bus/pci/devices/0000:0e:01.0/uio/
 -bash: cd: /sys/bus/pci/devices/0000:0e:01.0/uio/: No such file or directory
 [root@amc725 0000:0e:01.0]# ls
 broken_parity_status              device                    local_cpulist      power          resource0                  uevent
 class                                           dma_mask_bits    local_cpus          remove        resource2                  vendor
 config                                         driver                      modalias            rescan          subsystem                 vpd
 consistent_dma_mask_bits   enable                     msi_bus             reset             subsystem_device
 d3cold_allowed                        irq                           numa_node       resource      subsystem_vendor
-Jihwa
보낸 사람: Michael Davidsaver <[email protected]>
보낸 날짜: 2016년 3월 10일 목요일 오전 10:01
받는 사람: 김지화(빔라인장치팀); [email protected]; [email protected]
제목: Re: mrfioc2 error at uTCA platform
Before calling mrmEvrSetupPCI(), set the devPCIDebug variable to 5 (or
greater) to give some more output.
> var(devPCIDebug, 5)
What is the version of the Linux kernel you are running?
In order to make the association between the PCI device ID and /dev/uio#
device file, devlib2 follows of a symlink under /sys/.  The location of
this symlink has already changed once between 2.6.28 and 2.6.32.  It may
have changed again.
Look in "/sys/bus/pci/devices/0000:0e:01.0/" for "uio:uio0" or "uio/uio0".
https://github.com/epics-modules/devlib2/blob/master/pciApp/os/Linux/devLibPCIOSD.c#L266
Finally, does the kernel log (dmesg) give any messages when the mrfioc2
kernel module is loaded?
On 03/08/2016 09:55 PM, 김지화(빔라인장치팀) wrote:
> Hi Martin and Michael,
> I've attached error message.
>>> If the file '/dev/era3' exists
> Yes, I've been hard rebooted and there is not installed '/dev/era3'
>>> So you should see some file like '/dev/uio0'.
> Yes, I can see uio0 driver at /dev
>>> mrfioc2 and devlib2 are you using?
> I used mrfioc2 2.04 and devlib2.6, again it worked before but some reason it caused error.
> -Jihwa
> 보낸 사람: [email protected] <[email protected]> 대신 Michael Davidsaver <[email protected]>
> 보낸 날짜: 2016년 3월 8일 화요일 오후 12:05
> 받는 사람: [email protected]
> What version of mrfioc2 are you using?
>> Interesting is the SLAC evr version is correctly working.
>> evrIocTest_registerRecordDeviceDriver(pdbbase)
>> ErConfigure(0, 0, 0, 0, 1)
>> EvrOpen, device = /dev/era3
> If the file '/dev/era3' exists then you don't have the correct linux kernel module loaded.  mrfioc2 comes with it's own, which uses the UIO interface.  So you should see some file like '/dev/uio0'.
> On 03/07/2016 03:21 PM, 김지화(빔라인장치팀) wrote:
>> Hi Martin,
>>>> PMC EVR on a PMC carrier card, right?
>> Yes, right! Vadatech PMC Carier board.
>>>> What does "lspci" say? Maybe you've plugged the card into a different AMC slot?
>> I think slot is correct slot number because it worked before.
>>  Here is a PMC-EVR-230 with VID:DID 10b5:9030 and subvendor ID 1a3e
>> and subvendor device ID 11e6. (JUkka already confirmed )
>> [root@amc725 mrf_pci_driver]# lspci -nn -x
>> 0e:01.0 Signal processing controller [1180]: PLX Technology, Inc. PCI9030 32-bit 33MHz PCI <-> IOBus Bridge [10b5:9030] (rev 01)
>> 00: b5 10 30 90 02 00 90 02 01 00 80 11 08 00 00 00
>> 10: 00 00 a1 fd 00 00 00 00 00 00 a0 fd 00 00 00 00
>> 20: 00 00 00 00 00 00 00 00 00 00 00 00 3e 1a e6 11
>> 30: 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
>> EVR Found with Firmware Revision 0x11000007
>> Found a PMC_EVR /dev/era3
>> Jihwa
>> 보낸 사람: Konrad, Martin <[email protected]>
>> 보낸 날짜: 2016년 3월 7일 월요일 오후 1:37
>> Hi Jihwa,
>>  > Dose any one has experience of mrfioc2 evr driver for uTCA platform?
>>> PMC-EVR-230 firmware version: PMC-EVR-230-11000007.bit
>> I guess you are not using the native uTCA card but a PMC EVR on a PMC
>>> Using IRQ 16
>>> directory
>> AMC slot?
>> -Martin
>> Martin Konrad
>> Control System Engineer
>> Facility for Rare Isotope Beams
>> Michigan State University
>> 640 South Shaw Lane
>> East Lansing, MI 48824-1321, USA
>> Tel. 517-908-7253
>> Email: [email protected]
Re: mrfioc2 error at uTCA platform Michael Davidsaver
Re: mrfioc2 error at uTCA platform Konrad, Martin
RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
Prev: Re: mrfioc2 error at uTCA platform Michael Davidsaver
Next: mbbo/mbbi and bits subset [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: mrfioc2 error at uTCA platform Michael Davidsaver
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
