1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mrfioc2 error at uTCA platform
To: Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 9 Mar 2016 02:55:50 +0000
Hi Martin and Michael,
I've attached error message.
>>If the file '/dev/era3' exists
Yes, I've been hard rebooted and there is not installed '/dev/era3'
>>So you should see some file like '/dev/uio0'.
Yes, I can see uio0 driver at /dev
>>mrfioc2 and devlib2 are you using?
I used mrfioc2 2.04 and devlib2.6, again it worked before but some reason it caused error.
-Jihwa
보낸 사람: [email protected] <[email protected]> 대신 Michael Davidsaver <[email protected]>
보낸 날짜: 2016년 3월 8일 화요일 오후 12:05
받는 사람: [email protected]
제목: Re: mrfioc2 error at uTCA platform
What version of mrfioc2 are you using?
> Interesting is the SLAC evr version is correctly working.
> evrIocTest_registerRecordDeviceDriver(pdbbase)
> ErConfigure(0, 0, 0, 0, 1)
> EvrOpen, device = /dev/era3
If the file '/dev/era3' exists then you don't have the correct linux kernel module loaded.  mrfioc2 comes with it's own, which uses the UIO interface.  So you should see some file like '/dev/uio0'.
On 03/07/2016 03:21 PM, 김지화(빔라인장치팀) wrote:
> Hi Martin,
>>> PMC EVR on a PMC carrier card, right?
> Yes, right! Vadatech PMC Carier board.
>>> What does "lspci" say? Maybe you've plugged the card into a different AMC slot?
> I think slot is correct slot number because it worked before.
>  Here is a PMC-EVR-230 with VID:DID 10b5:9030 and subvendor ID 1a3e
> and subvendor device ID 11e6. (JUkka already confirmed )
> [root@amc725 mrf_pci_driver]# lspci -nn -x
> 0e:01.0 Signal processing controller [1180]: PLX Technology, Inc. PCI9030 32-bit 33MHz PCI <-> IOBus Bridge [10b5:9030] (rev 01)
> 00: b5 10 30 90 02 00 90 02 01 00 80 11 08 00 00 00
> 10: 00 00 a1 fd 00 00 00 00 00 00 a0 fd 00 00 00 00
> 20: 00 00 00 00 00 00 00 00 00 00 00 00 3e 1a e6 11
> 30: 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
> EVR Found with Firmware Revision 0x11000007
> Found a PMC_EVR /dev/era3
> Jihwa
> 보낸 사람: Konrad, Martin <[email protected]>
> 보낸 날짜: 2016년 3월 7일 월요일 오후 1:37
> 받는 사람: 김지화(빔라인장치팀); [email protected]
> Hi Jihwa,
>  > Dose any one has experience of mrfioc2 evr driver for uTCA platform?
>> PMC-EVR-230 firmware version: PMC-EVR-230-11000007.bit
> I guess you are not using the native uTCA card but a PMC EVR on a PMC
>> mrmEvrSetupPCI("PMCEVR",0xe,1,0)
>> Device PMCEVR 14:1.0
>> Using IRQ 16
>> Failed to open uio device for PCI device 0000:0e:01.0: No such file or
>> directory
>> Failed to enable interrupt
> AMC slot?
> -Martin
> Martin Konrad
> Control System Engineer
> Facility for Rare Isotope Beams
> Michigan State University
> 640 South Shaw Lane
> East Lansing, MI 48824-1321, USA
> Tel. 517-908-7253
> Email: [email protected]
Attachment: ErrorMessage_20160309.png
Description: ErrorMessage_20160309.png
Re: mrfioc2 error at uTCA platform Michael Davidsaver
Re: mrfioc2 error at uTCA platform Konrad, Martin
RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
Prev: Re: Array of strings with asyn? Vasquez Stanescu, Jesus A
Next: Re: Q: Are any tools using gui_group() properties? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mrfioc2 error at uTCA platform Michael Davidsaver
Next: Re: mrfioc2 error at uTCA platform Michael Davidsaver
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
