1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mbbo/mbbi and bits subset
Date: Thu, 10 Mar 2016 14:51:49 +0000
> but I cannot give a value to mbbo greater than (2^16)-1 (e.g. the value of a 32-bit register)
I don't think that is true. I just did a test using asyn/testEpics. I changed devDigital.db as follows:
corvette:asyn/iocBoot/ioctestEpics>git diff
diff --git a/testEpicsApp/Db/devDigital.db b/testEpicsApp/Db/devDigital.db
index 88bd630..63d36eb 100644
--- a/testEpicsApp/Db/devDigital.db
+++ b/testEpicsApp/Db/devDigital.db
@@ -16,7 +16,7 @@ record(longout,"asyndevLoUInt32") {
 record(mbbo,"asyndevMbboUInt32") {
     field(DTYP,"asynUInt32Digital")
-    field(OUT,"@asynMask(digital,0,0xf,1.0) ")
+    field(OUT,"@asynMask(digital,0,0xffffffff,1.0) ")
     field(ZRST,"zero")
     field(ONST,"one")
     field(TWST,"two")
@@ -34,8 +34,8 @@ record(mbbo,"asyndevMbboUInt32") {
     field(FTST,"fourteen")
     field(FFST,"fifteen")
     field(ZRVL,"0x0")
-    field(ONVL,"0x1")
-    field(TWVL,"0x2")
+    field(ONVL,"0x100000")
+    field(TWVL,"0x200000")
     field(THVL,"0x3")
     field(FRVL,"0x4")
     field(FVVL,"0x5")
So I increased the mask from 0xf to 0xffffffff, i.e. all 32-bits.  I changed the ONVL and TWVL values to be larger than 16 bits.
I then ran the iocBoot/ioctestEpics IOC.
This is the output of dbl on that record:
epics> dbpr asyndevMbboUInt32 10
ACKS: NO_ALARM      ACKT: YES           ASG:                ASP: (nil)
BKPT: 00            COSV: NO_ALARM      DESC:               DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DOL:CONSTANT
DPVT: 0xa6c240      DSET: 0x7f5a5eaf8200
DTYP: asynUInt32Digital                 EIST: eight         EISV: NO_ALARM
EIVL: 0x8           ELST: eleven        ELSV: NO_ALARM      ELVL: 0xb
EVNT: 0             FFST: fifteen       FFSV: NO_ALARM      FFVL: 0xf
FLNK:CONSTANT 0     FRST: four          FRSV: NO_ALARM      FRVL: 0x4
FTST: fourteen      FTSV: NO_ALARM      FTVL: 0xe           FVST: five
FVSV: NO_ALARM      FVVL: 0x5           IVOA: Continue normally
IVOV: 0             LALM: 0             LCNT: 0             LSET: 0xa70120
MASK: 4294967295
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: a0 f9 a4 00 00 00 00 00           MLST: 0
NAME: asyndevMbboUInt32                 NIST: nine          NISV: NO_ALARM
NIVL: 0x9           NOBT: 0             NSEV: NO_ALARM      NSTA: NO_ALARM
OMSL: supervisory   ONST: one           ONSV: NO_ALARM      ONVL: 0x100000
ORAW: 0             ORBV: 0
OUT:INST_IO @asynMask(digital,0,0xffffffff,1.0)             PACT: 0
PHAS: 0             PINI: NO            PPN: (nil)          PPNR: (nil)
PRIO: LOW           PROC: 0             PUTF: 0             RBV: 0
RDES: 0xa0d8e0      RPRO: 0             RSET: 0x7f5a5e880000
RVAL: 0             SCAN: Passive       SDEF: 1             SDIS:CONSTANT
SEVR: INVALID       SHFT: 0             SIML:CONSTANT       SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT       SPVT: (nil)         STAT: UDF
SVST: seven         SVSV: NO_ALARM      SVVL: 0x7           SXST: six
SXSV: NO_ALARM      SXVL: 0x6           TEST: ten           TESV: NO_ALARM
TEVL: 0xa           THST: three         THSV: NO_ALARM      THVL: 0x3
TIME: <undefined>   TPRO: 0             TSE: 0              TSEL:CONSTANT
TTST: thirteen      TTSV: NO_ALARM      TTVL: 0xd           TVST: twelve
TVSV: NO_ALARM      TVVL: 0xc           TWST: two           TWSV: NO_ALARM
TWVL: 0x200000      UDF: 0              UNSV: NO_ALARM      VAL: 0
ZRST: zero          ZRSV: NO_ALARM      ZRVL: 0x0
So you can see that ONVL and TWVL values are more than 16 bits.
I then set the asynTrace masks so I would get debugging output from the driver.
epics> asynSetTraceIOMask digital 0 6
epics> asynSetTraceMask digital 0 255
I then set the record VAL field to 1:
epics> dbpf asyndevMbboUInt32.VAL 1
2016/03/10 08:42:43.185 digital queueRequest synchronous
2016/03/10 08:42:43.185 digital 0 autoConnect
2016/03/10 08:42:43.185 digital uint32DigitalDriver:connect addr 0
2016/03/10 08:42:43.185 asynRecord: exception 0, asynExceptionConnect
2016/03/10 08:42:43.185 digital uint32DigitalDriver:writeInt32 value 1048576
2016/03/10 08:42:43.185 digital addr 0 write 1048576
2016/03/10 08:42:43.185 asyndevBiUInt32Bit0 devAsynUInt32Digital::interruptCallbackInput new value=1048576
2016/03/10 08:42:43.185 asyndevBiUInt32Bit1 devAsynUInt32Digital::interruptCallbackInput new value=1048576
2016/03/10 08:42:43.185 asyndevLiUInt32 devAsynUInt32Digital::interruptCallbackInput new value=1048576
2016/03/10 08:42:43.185 asyndevMbbiUInt32 devAsynUInt32Digital::interruptCallbackInput new value=1048576
2016/03/10 08:42:43.185 asyndevMbbiDirectUInt32 devAsynUInt32Digital::interruptCallbackInput new value=1048576
2016/03/10 08:42:43.185 asyndevMbboUInt32 devAsynUInt32Digital process value 1048576
DBR_STRING:          "one"
2016/03/10 08:42:43.185 asyndevBiUInt32Bit0 devAsynInt32::getCallbackValue from ringBuffer value=1048576
2016/03/10 08:42:43.185 epics> asyndevBiUInt32Bit1 devAsynInt32::getCallbackValue from ringBuffer value=1048576
2016/03/10 08:42:43.185 asyndevLiUInt32 devAsynInt32::getCallbackValue from ringBuffer value=1048576
2016/03/10 08:42:43.185 asyndevMbbiUInt32 devAsynInt32::getCallbackValue from ringBuffer value=1048576
2016/03/10 08:42:43.185 asyndevMbbiDirectUInt32 devAsynInt32::getCallbackValue from ringBuffer value=1048576
So you can see that the driver wrote the value 1048576, which is hex 0x100000.
I then set the VAL field to 2 and again the driver wrote the expected value of 2097152= 0x200000.
epics> dbpf asyndevMbboUInt32.VAL 2
2016/03/10 08:49:55.087 digital queueRequest synchronous
2016/03/10 08:49:55.087 digital uint32DigitalDriver:writeInt32 value 2097152
2016/03/10 08:49:55.087 digital addr 0 write 2097152
2016/03/10 08:49:55.087 asyndevBiUInt32Bit0 devAsynUInt32Digital::interruptCallbackInput new value=2097152
2016/03/10 08:49:55.087 asyndevBiUInt32Bit1 devAsynUInt32Digital::interruptCallbackInput new value=2097152
2016/03/10 08:49:55.087 asyndevLiUInt32 devAsynUInt32Digital::interruptCallbackInput new value=2097152
2016/03/10 08:49:55.087 asyndevBiUInt32Bit0 devAsynInt32::getCallbackValue from ringBuffer value=2097152
2016/03/10 08:49:55.087 asyndevMbbiUInt32 devAsynUInt32Digital::interruptCallbackInput new value=2097152
2016/03/10 08:49:55.087 asyndevMbbiDirectUInt32 devAsynUInt32Digital::interruptCallbackInput new value=2097152
2016/03/10 08:49:55.087 asyndevMbboUInt32 devAsynUInt32Digital process value 2097152
DBR_STRING:          "two"
2016/03/10 08:49:55.087 asyndevBiUInt32Bit1 devAsynInt32::getCallbackValue from ringBuffer value=2097152
epics> 2016/03/10 08:49:55.087 asyndevLiUInt32 devAsynInt32::getCallbackValue from ringBuffer value=2097152
2016/03/10 08:49:55.087 asyndevMbbiUInt32 devAsynInt32::getCallbackValue from ringBuffer value=2097152
2016/03/10 08:49:55.087 asyndevMbbiDirectUInt32 devAsynInt32::getCallbackValue from ringBuffer value=2097152
So I don't see any evidence that the values written by the mbbo record are limited to 16 bits.
Sent: Thursday, March 10, 2016 8:29 AM
To: Mark Rivers
Cc: [email protected]
ok,
Gennaro
On Thu, 10 Mar 2016, Mark Rivers wrote:
> Hi Gennaro,
> The mbbo record has 16 enum choices. However, the values associated with each enum choice are 32-bit integers. So you can access all 32 bits in your register using an mbbo record.
> Mark
> From: [email protected] [[email protected]]
> Sent: Thursday, March 10, 2016 8:19 AM
> To: Mark Rivers
> Hi,
> I just realized that a mbbo can contain up to 16 bit value...
> it is possible to specify that a record can contain a 32 bit value ?
> the record documentation does not provide this information...
> Regards,
> Gennaro
> On Thu, 10 Mar 2016, [email protected] wrote:
>> Hi Mark,
>> I did it with your suggestion by asynMask and everything works fine !!
>> Thanks,
>> Gennaro
>>> Hi Gennaro,
>>> You can do what you want using the asynUInt32Digital support and the
>>> @asynMask INP syntax.
>>> record(mbbo,"Acquire") {
>>> field(OUT,"@asynMask(myPort , 0, 0x3 , 1.0) ")
>>> field(ZRST,"Start acquire")
>>> field(ONST,"Stop acquire")
>>> field(ZRVL,"0x2")
>>> field(ONVL,"0x3")
>>> You can use multiple mbbo/mbbi records to access different adjacent bits in
>>> your register using this technique.
>>> The asyn device support uses the NOBT, SHFT, and MASK fields of the
>>> mbbo/mbbi records documented here:
>>> https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Multi-Bit_Binary_Output
>>> Mark
>>> From: [email protected] [[email protected]] on
>>> behalf of [email protected] [[email protected]]
>>> Sent: Thursday, March 10, 2016 4:54 AM
>>> To: [email protected]
>>> Subject: mbbo/mbbi and bits subset
>>> Hi,
>>> I'm using mbbo and mbbi record types to write and read
>>> some registers from/to ASYN driver I'm developing;
>>> some registers refers to a single aspect of acquisition
>>> (e.g. channel threshold) and with a simple mbbo record
>>> to write and a mbbi record to read back, everything works
>>> fine...
>>> other registers refers to a setup/control functions
>>> and using the same mbbo/mbbi approach works fine if
>>> the user address (read/write) every time the whole register;
>>> I know mbboDirect for bitwise access of a record value but
>>> is there a method to address (read/write) through a record
>>> a "bits subset" of a "main" mbbo record ?
>>> e.g. acquisition control:
>>> bit[16...2] <don't care>
>>> bit[1...0]
>>> 11 stop acquisition
>>> 10 start acquisition
>>> 01 do something...
>>> 00 do something...
>>> which is a simple method to access "directly" bitset [0...1]
>>> in order to have a record I can use to write 11 (3) to stop acquisition,
>>> 10 (2) to start acquisiton and so on ?
>>> Thanks in advance,
>>> Gennaro
>>> Gennaro Tortone
>>> INFN Napoli
>>> Italy
>>> tel: +39 81 676169
>>> "Computer Science is no more about computers
>>> than astronomy is about telescopes."
>>> - Edsger Dijkstra
> Gennaro Tortone
> INFN Napoli
> Italy
> tel: +39 81 676169
> - Edsger Dijkstra
Gennaro Tortone
INFN Napoli
Italy
tel: +39 81 676169
- Edsger Dijkstra
mbbo/mbbi and bits subset [email protected]
RE: mbbo/mbbi and bits subset Mark Rivers
RE: mbbo/mbbi and bits subset [email protected]
Prev: RE: mbbo/mbbi and bits subset [email protected]
Next: stream protocol question: ASCII hex to 32-bit float Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: mbbo/mbbi and bits subset Andrew Johnson
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
